Lazy Headlamp
Old Mar 16, 2003 | 04:18 PM
don hall's Avatar
don hall
Default Re: Lazy Headlamp (lani's 93)
Lani, are you aware that there is a manual control **** for each headlight door? It is advised that you do not move/force the light asm. by any other means. I'll do some research, and see if we can't solve your problem. Let's hope others have some suggestions.
Old Mar 16, 2003 | 06:46 PM
don hall's Avatar
don hall
Lani, raise the hood, and near the radiator at the front of the engine are two black ***** that have direction arrows on them. These ***** can be rotated to raise and lower the headlight asm. You can just leave asm. in the "up" position until you get your problem sorted out.
