84 with inconsistent idle when hot
Old Mar 16, 2003 | 09:59 PM
rogerbluechip's Avatar
rogerbluechip
7th Gear
Default 84 with inconsistent idle when hot
TPS is about a year old. No codes. Idle is irratic when hot and appears somewhat low (600 rpm) at idle. I think I need to start with a voltage check of the TPS. What voltage should it be? I know the check is between A and B terminals, according to the book, but none of the terminals are marked. How can I tell A and B? Also, I've seen some guys talk about the IAC going bad at about 80,000. Could that be it? If so what is it and how hard to fix?
