How to replace an antena mast
Old Mar 17, 2003 | 12:55 AM
Tolofou's Avatar
Tolofou
Default How to replace an antena mast
On the convertible how do you work on the antenna mast..
Old Mar 17, 2003 | 10:55 AM
ROADAPPLE's Avatar
ROADAPPLE
Default Re: How to replace an antena mast (Tolofou)
To replace the mast the entire assembly must be removed from the car first. It helps if you remove the wheel and tire for easier access. After you have disasembled the motor do not forget to remove both pieces of the broken mast.
Good day,
Old Mar 17, 2003 | 02:42 PM
safety_match's Avatar
safety_match
Navigator
Although I have heard some will remove the rear license plate, then the back up light housing, then the inboard brake light housing, then the outboard brake light housing, then reach in...I just recently replaced the power antenna on my 1990 convertible and I did it this way:
Jack up the left side, remove the left rear wheel, remove the plastic inner fenderwell, reached up from below (just inside body) and removed the motor entirely. I am no mechanic and I guess I spent about 2 hours to complete the job. The power antenna motor was about $155 Canadian (approximately $100 US) and purchased at a "trade" discount at my local GM dealer. Inventory is in good supply.
Good luck! :thumbs:
Old Mar 17, 2003 | 03:09 PM
Tolofou's Avatar
Tolofou
Default Re: How to replace an antena mast (safety_match)
Thanks.. This gives me an idea on how to tackel it.. I think the mast cord is broken and I have a new mast to install..
Rob :thumbs:
Old Mar 17, 2003 | 04:45 PM
Steel Blue 91's Avatar
Steel Blue 91
I assume the vert and coupe are the same. If all you need is the mast, check the following thread:
http://forums.corvetteforum.com/zerothread?id=420507
Hope it helps.
To How to replace an antena mast
