Low coolant light problem solved.
Old Mar 17, 2003 | 07:17 PM
EBrown's Avatar
EBrown
Default Low coolant light problem solved.
The low coolant light has been coming on and going off for the past several months after taking it to the dealer and corvette shop, I found the problem myself. I took the overflow bottle out and low and behold the tube was clogged up, the little brass piece that fits into the bottle was clogged and the top of the bottle was coverd in gunk, I cleand out the bottle and reinstalled and presto no low coolant light, I wish all problems were this simple. :lol:
Old Mar 17, 2003 | 07:24 PM
sumoboy's Avatar
sumoboy
Default Re: Low coolant light problem solved. (EBrown)
Glad to hear good news. :thumbs: :steering:
Old Mar 17, 2003 | 10:12 PM
don hall's Avatar
don hall
Your job isn't finished. The "gunk", to which you referred, came from your cooling system. It is time (past time) to flush the system, or the problem will recur.
Old Mar 18, 2003 | 11:29 AM
BADMUDE's Avatar
BADMUDE
Default Re: Low coolant light problem solved. (Oldman)
Good tip..I need to check mine... :thumbs:
Old Mar 18, 2003 | 03:02 PM
beachcat's Avatar
beachcat
Default Re: Low coolant light problem solved. (BADMUDE)
Stupid question, where is the low coolant temp switch on an 87?
Old Mar 18, 2003 | 03:16 PM
John Row's Avatar
John Row
So, what was the total cost to clean out the gunk?
My $12 relay cost me $147.97! Plus, untold hours of grief from my wife :banghead: .
Old Mar 18, 2003 | 03:23 PM
don hall's Avatar
don hall
Default Re: Low coolant light problem solved. (beachcat)
... where is the low coolant temp switch on an 87?..
Good link to sensors......http://www.c4vettes.com/sensorinformation.htm
Old Mar 18, 2003 | 03:27 PM
beachcat's Avatar
beachcat
Nice info at the link, thanks. But I did not see the low coolant temp sensor, is it under a different name?
Old Mar 18, 2003 | 03:40 PM
don hall's Avatar
don hall
...I did not see the low coolant temp sensor....
Oops! :bb There may not be one on an '87. None shown in my manuals. That doesn't mean that it doesn't exist. Maybe someone will confirm this........
Old Mar 18, 2003 | 04:03 PM
beachcat's Avatar
beachcat
No problem, I dont see one in my manual either.
What is the sensor on the radiator , below the cap?
Old Mar 18, 2003 | 05:22 PM
don hall's Avatar
don hall
....What is the sensor on the radiator , below the cap?..
If I were a gambler, I'd bet that is your low coolant sensor.................
Old Mar 18, 2003 | 05:35 PM
beachcat's Avatar
beachcat
In the big scheme of things, what is it's purpose? Just to turn on a light that says Coolant? Would it have anohter purpose also?
Old Mar 18, 2003 | 05:41 PM
don hall's Avatar
don hall
It may be a warning of low coolant so that you can correct the situation prior to the coolant temperature light coming on. Not sure.
Old Mar 18, 2003 | 05:59 PM
John Steen's Avatar
John Steen
On the 87 you have:
Low Coolant Module.................Behind I/P, near Fues Block
Low Coolant Sensor..................RH front of engine, on radiator
:thumbs:
To Low coolant light problem solved.
