This is soooo coool
Old Mar 18, 2003 | 04:49 PM
Mervz's Avatar
Mervz
Cruise-In V Veteran
Cruise-In VI Veteran
Default This is soooo coool
Just a few mintues ago i offically entered the world of PCM "tuning". :D
With Tunercat, it was easier than i ever thought!! My 1995 was re flashed without a hitch and with ZERO problems.
Although i didn't do much right now (just skip shift elimination, cooling fans at a lower temperature, etc..) i feels pretty good. :cheers:
Old Mar 18, 2003 | 06:17 PM
HighHopes85's Avatar
HighHopes85
Default Re: This is soooo coool (Mervz)
[yoda]Mmmm...the force is strong with this one[/yoda]
With a PCM, just make sure your battery is always fully charged before you flash. :thumbs:
Old Apr 17, 2003 | 11:24 PM
GlockLT4's Avatar
GlockLT4
Default Re: This is soooo coool (HighHopes85)
CONGRATS! Now .. DO NOT let your battery die when you do that or you run into the MILES of problems i had :crazy:
Now that i have the LT4 i'm stuck with still trying to find a cheap scanner and program to do editing/logging with :(
Old Apr 19, 2003 | 01:49 PM
tjwong's Avatar
tjwong
Default Re: This is soooo coool (GlockLT4)
If heaven forbid you ever mess up and fry your PCM :cry let me know I can fix it for you. I can socket your PCM and reflash your chips for you. :auto:
Old Apr 19, 2003 | 03:53 PM
GlockLT4's Avatar
GlockLT4
Default Re: This is soooo coool (tjwong)
:yesnod:
:cool: .. the guy from AKM cables did mine for me... thank GOD he knew how to do that. I killed my 383 when i was programming it after having only driven it for 10 minutes with the new engine, lol. It was soooooo mad.
Old Apr 19, 2003 | 05:51 PM
tjwong's Avatar
tjwong
Yes, I know Andy there. He has since stopped doing socketing of PCMs now. I purchased the last remaining stock of Intel Flash chips for the PCMs from on company that my dad knew about. I think there are a couple of others doing it as well. I usually have a couple PCMs on hand so it can even be on an exchange basis if one doesn't want to wait. I have access to GM calibrations if virgin files are necessary or if one just wants a virgin file for their cars.
To This is soooo coool
