L98 guys...
Old Mar 20, 2003 | 04:50 PM
TA's Avatar
TA
Default Re: L98 guys... (Jim85IROC)
how would i clean out a clogged cat? if that's not it, how should i go about tuning it?
Broomstick.
:yesnod: :yesnod:
Old Mar 20, 2003 | 05:26 PM
Raistlin's Avatar
Raistlin
Default Re: L98 guys... (Feenix566)
here's my "mods":
K&N air filter in stock air box
air foil
Flowmasters & catback y-pipe
removed frisbee
160 degree thermostat
also, it's a four-speed automatic and it has 101k miles on it.
[Modified by Feenix566, 1:14 PM 3/20/2003]
with those mods, you should be at least 100mph, probably 102.
any exhaust shop can do a backpressure test to determine if any of the 3 cats are clogged. I had that done trying to find why I was down on power. My cats were fine.
check your base timing, it should be 6* BTDC. don't forget to unplug the tan wire by the firewall, it'll keep the computer from changing the timing on you. This was my problem. I had the car at the Pontiac dealership I used to work at and told them to set the timing. I went through days of crap, then decided to check it myself. It was set at 6* ATDC. Last time I took my car there.
when was the last time you did a tune up? You should change cap, rotor, wires, spark plugs. I also changed the module in the dist. I got an Accel part from AutoZone (or Advance, I can never remember)
You may also want to invest in scanning software. If you have a laptop, you'lll need a cable ~$90 and software, ~$FREE on up. I'm using the AKM cable and TTS Datamaster. I'm only just getting started using the scans, but it gives a wealth of information. Go to the C4 scan and tune section and read the FAQ. There is a good FAQ at thirdgen.org, too.
You'll also want to check your fuel pressure. I picked up a guage at the local autoparts store. Checked fuel pressure at idle then taped the guage to the window and went for a drive. You should probably change the fuel filter, if you haven't all ready.
You can also check for a bad fuel injector using a Volt/Ohm Meter. The resistance across all the injectors should be similar and somewhere around 17 or 16. (that's a guess from my poor memory)
[Modified by Raistlin, 5:31 PM 3/20/2003]
Old Mar 20, 2003 | 05:47 PM
Dr. Evil's Avatar
Dr. Evil
CI 1-2-3-4-5-6-7-8 Veteran
CI-IV AutoX Champ
CI-IV Burnout Champ
St. Jude Donor '07-'10
Default Re: L98 guys... (Raistlin)
13.5 at 105.xx mph with a 2.09 60 foot. 1990 coupe,6 speed, street tires, true duals, no cats, shorty headers, muffler elims, afpr, free mods, cut lid with KN, accell base, air foil, air pump eliminator kit.
Old Mar 20, 2003 | 06:27 PM
Matt383's Avatar
Matt383
From: 2003 Points Champ Great Lakes Corvette Challenge; 2006/2007 Winner MSD True Street
Default Re: L98 guys... (Dr. Evil)
Mods in Sig.
11.4 motor only.
mid 10's "on the bottle" :steering:
Old Mar 20, 2003 | 06:32 PM
Magic91's Avatar
Magic91
Remove the pre converter.......the best and cheapest, You can do!
Old Mar 20, 2003 | 08:14 PM
tucsonvette's Avatar
tucsonvette
Default Re: L98 guys... (Magic91)
1st time for me...14.6 @ 95.2. and thats at 3300 ft :(
Old Mar 20, 2003 | 08:44 PM
Mr. Magoo's Avatar
Mr. Magoo
From: Damn taxes! Pimpin' Ain't Easy in Massachusetts
2018 C4 of Year Finalist
St. Jude Donor '03-'04-'08-'09
I first started with a cat back exhaust from Flowmaster, with a Walker Y-Pipe and Random Tech Cat as my first mod on my '86 Auto. Then I changed my rear gears from 2.59 to 3.73's. This was my first mistake though and I will be removing them at a later date. Waaaaaay too much gear!! :crazy: But hey they were free. :)
Next list of mods were K&N, 160 Stat, Open air lid, Air foil, SVO 24lb injectors, Accel 8.8mm wires, chip, walbro fuel pump, Ported Plenum, AS&M runners, Ported Base, Air Pump Eliminator kit & March Pulleys.
My track results were very poor because I found out my Throttle Body was not working properly and opening LESS than half way. :eek: I never made a pass with the TB fixed and could only run a best of 14.01 & 96 MPH. :( :cry
But since then I fixed this and bought a set of Lingenfelter Headers, a SLP Converter and a NX nitrous kit with all the saftey features! :cool: :cheers:
IT NEVER ENDS!! :lol: :cheers:
Good luck!
Old Mar 20, 2003 | 10:36 PM
Feenix566's Avatar
Feenix566
Default Re: L98 guys... (Mr. Magoo)
thanx for all the input guys!
It never ceases to amaze me how knowledgable everyone on this forum is.
I love you guys! :hurray:
I think my first step will be to have an exhaust shop do the backpressure test. Then I'll go replace the spark wires and fuel filter. There's a good chance those parts are 13 years old.
Old Mar 21, 2003 | 01:10 PM
DarthD's Avatar
DarthD
14.3 @ 95 Bone stock. Out of 28 roadtests from magazines that I have collected, the average for a Factory Stock L98 Corvette is 14.5 @ 95.
The Quickest was 13.90 and the slowest was 15.20.
[Modified by DarthD, 6:16 PM 3/21/2003]
Old Mar 21, 2003 | 02:48 PM
Feenix566's Avatar
Feenix566
Default Re: L98 guys... (DarthD)
I ran a 14.7 bone stock.
I called two exhaust shops, and both of them told me that there is no backpressure test.
Myabe I'll just take a broomhandle to the cat and see what happens.
Old Mar 21, 2003 | 04:36 PM
TIMSPEED's Avatar
TIMSPEED
With mods listed on this site ~> www.cardomain.com/id/timspeed
I've ran a 13.6@100 with a 1.85 60' on my regular 275/40 Potenza RE730's. When I was at the track last time, I had my timing up at like 8º BTDC. I'm gonna change it back to 6º BTDC and try it again, then maybe put it at 10º and see..I just am really looking to get a 13 flat out of this combo...
Old Mar 21, 2003 | 05:17 PM
Raistlin's Avatar
Raistlin
i watched the guy at Meineke do the pressure test on my car. It's pretty straight foward. they just stick a pressure sensor in the exhaust before and after the cats and measure the difference. Maybe the shops you called didn't have the equipment.
Checking the throttle body for full opening is a good idea. I was trying to figure out why I wasn't getting full TPS voltage on my scans. I replaced the TPS, and still no full voltage. I finally noticed the throttle gear was hitting a worm clamp :bb
Old Mar 21, 2003 | 05:20 PM
  #33
scorp508's Avatar
scorp508
Stock: 13.89 @ 98.17
Now: 12.89 @ 109.66 out of tune and <cringe> 2.2 60' times. Lots more to go! :cheers:
Old Mar 27, 2003 | 01:59 PM
  #34
Feenix566's Avatar
Feenix566
Default Re: L98 guys... (scorp508)
I may have found en explanation for my bad quarter mile times. Yesterday I got into the car to go to work, and the power brakes weren't working. So instead of going to work, I took it over to the dealership. After inspecting it, they told me the reason for the brakes' failure was that my intake manifolds were so clogged with carbon that the brakes weren't getting any air. I didnt even know the brakes were attached to the intake manifolds! Anyway, they cleaned out my TPI, and now the car's running smoother than ever. So maybe next time I go to the track my times will improve.
:) :chevy
Old Dec 2, 2004 | 04:31 PM
  #35
88BlackZ-51's Avatar
88BlackZ-51
Originally Posted by Feenix566
I have a few questions for the L98 guys (and gals).
What's your best quarter mile time? What's the best quarter mile time ever posted by a normal tuner with an L98? In what order should I start doing modifications?
stock i ran a 14.31@98.6MPH with a crappy 2.21 6o foot.
had i got the 60 down to 2.00, i would of been a 14.00 or so.
Old Dec 2, 2004 | 04:41 PM
  #36
scorp508's Avatar
scorp508
Your brake booster is connected to a vaccuum fitting on your intake manifold. If the became carbon polluted (I honestly can't really picture that) then your brakes would get no vaccuum assist.
