ZR1 offset wheels on regular vette?
Old Dec 1, 2004 | 01:20 PM
ToyC4's Avatar
ToyC4
St. Jude Donor '05
Default ZR1 offset wheels on regular vette?
I'm picking up a set of wheels to race with and they're ZR1 offset with 11" rear wheels. Is it possible to run ZR1 offset wheels on a regular vette? What will this look like?
The front rims are the same size and offset so that's not the problem I'm worried about the rears. I know grand sport offset wheels are no problem so I'm comparing the two offsets but I'm not sure what this means.
Grand Sport rear is: +36.5 mm w/ 7.397 backset
ZR1 rear offset is: +50 mm w/ 7.93 backset
Old Dec 1, 2004 | 01:31 PM
purplemajesty's Avatar
purplemajesty
The rears will fit, they will just stick out of the fender wells.
Old Dec 1, 2004 | 01:34 PM
ToyC4's Avatar
ToyC4
St. Jude Donor '05
ok good - I've got a set of AFS now with the 11" rear but these are the Grand sport offset
thanks!
Joe
Old Dec 1, 2004 | 01:43 PM
vader86's Avatar
vader86
You have it backwards, GS rears are 50mm and ZR1 wheels are 38mm.
ZR1 rears on a 92 will stick out from the fender wheels, by almost an inch.
Old Dec 1, 2004 | 01:47 PM
Shore's Avatar
Shore
This man is right.The ZR1 rea was wider and the differetn offset kept the wheels right at the wheel well.The Grandsport had flares but not to the extent of the wider ZR1 rear end Hence the wheel nedgin to tuck in a touch more.
Old Dec 1, 2004 | 02:37 PM
Strick's Avatar
Strick
When using the ZR-1 offset wheels and 315/35 tires on a regular Vette, wil they rub the fenders in hard turns? (OEM suspension)
Old Dec 1, 2004 | 02:53 PM
ToyC4's Avatar
ToyC4
St. Jude Donor '05
Good question because I'm planning on using these wheels for autocrossing (street mod 2)
Old Dec 1, 2004 | 07:15 PM
vader86's Avatar
vader86
315s should not rub, 335s will.
Old Dec 2, 2004 | 01:56 PM
HummelS's Avatar
HummelS
See my ad for my '85 in the FS section - I'm running 315's on ZR1 11" - there's a rear shot in the ad.
Old Dec 2, 2004 | 02:34 PM
ToyC4's Avatar
ToyC4
St. Jude Donor '05
thanks I'll check it out !
Old Dec 2, 2004 | 04:59 PM
Zix's Avatar
Zix
I had ZR1 offset A-molds on my 96 for about a year before I switched to black GS-style ones. The stuck out, but only about 1/2 inch. Honestly, when I bought them I didn't even know they were ZR1 offset, and when I mounted them they certainly didn't stick out nearly enough for me to think they were. You can always ger a set of GS fender flares to cover them up as well.
To ZR1 offset wheels on regular vette?
