custom c-4 plenums now available
Can't wait to hear about the package with those dyno results...if possible! :)
Also, the IAC valve could inetrefer with the top of the thermo housing, but this can be gotten around too.
I'm sure he will fill us in with answers on these questions.
The runner length is what is most important, I think, since it is a middle ground length being between the Super Ram and Mini Ram. This as we all know determines where the torque is generated.
I agree. I think it would be great to get dyno numbers from this system too, but the fact is, it's not going to be much (if at all) different than the same system with Holley's plenum. The plenum doesn't make that much of a difference! The Holley stealth ram is a proven power maker, and considering how cheap the Holley or Grumpy's setup is, all the nay-sayers should just buy the damned thing and try it before they start trying to string up Grumpy by his toes. I'm not in support of or against Grumpy or anybody else here, but like Grumpy, I've followed the whole stealth ram saga from the beginning and the fact that there is now a plenum available for C4 guys should be a reason for people to be excited, not bite the hand that feeds. :confused:
http://www.eecis.udel.edu/~davis/z28...age021105.html
[Modified by ld85, 6:32 AM 3/23/2003]
AS YOU SEE THE RESULT IS THAT ON THAT dyno run THERE was a 66 hp gain over A PORTED TPI AFTERMARKET INTAKE, MOST IMPORTANT I THINK IS THE FACT THAT THE RUNNER LENGTHs WERE CUT DOWN TO ABOUT 3" (like a MINI-RAM) and the PORTS WERE LARGER THAN THE STOCK CHEVY TPI IN THAT EDELBROCK INTAKE BASE, BOTH FACTORS SHOW THAT THE STOCK TPI INTAKE IS EVEN MORE RESTRICTIVE. THE HOLLEY INTAKE WILL SHOW AN EVEN LARGER GAIN IF THE COMPRESSION AND CAM DURATION ARE INCREASED TO THAKE ADVANTAGE OF THE FAR GREATER AIR FLOW AND RAM EFFECT THE HOLLEY INTAKE PROVIDES
[Modified by grumpyvette, 4:14 PM 3/23/2003]
Just a couple of comments that might help performance and increase sales.
1) Mask the throttle body face of the plenum during powder coating. When you peel the masking off you'll have bare, machined aluminum. This will give the throttle body gasket a smoother surface to seal against. Typical powder coat is .003"-.010" thick and some (like yours appears) are highly textured. Even if you torque down the 4 TB bolts as tight as possible without stripping the threads in the aluminum plenum, you might not get enough clamping force to drive the thin paper gasket into all the powder coat texture, resulting in a vacuum leak. There is a lot of TB gasket surface area! Check with the powder coater but masking that surface should cost less than $1. (also, since the TB covers this area I doubt it would be subject to "greasy fingerprints" or "corrosion".....which is actually oxidation)
2) Pick a powder color as close to 'natural' aluminum as possible. I'd suggest taking a Holley SR intake manifold to the powder coater and ask them to match it as best they can. If they have nothing close in color then ask them to get the right color or find another powder coater. My guess is that your sales will go up if it looks more uniform in color and doesn't look like an "add-on". You know how most Vette guys/gals are about apprearance of their 'babies'...... :)
Just my 2 cents.
:seeya
BOTH FACTORS SHOW THAT THE STOCK TPI INTAKE IS EVEN MORE RESTRICTIVE. THE HOLLEY INTAKE WILL SHOW AN EVEN LARGER GAIN IF THE COMPRESSION AND CAM DURATION ARE INCREASED TO THAKE ADVANTAGE OF THE FAR GREATER AIR FLOW AND RAM EFFECT THE HOLLEY INTAKE PROVIDES.
:cheers:
http://www.chevytalk.org/forums/Foru...ML/000534.html
HSR::
355, AFR 195 street port, 224/224 560/560, auto camaro = 380rwhp, 432rwtq http://www.thirdgen.org/techbb2/show...ight=224%2F224
GM High Tech Performace 2 part HSR, 1st part = May '03
350 AFR 190, HOT cam, ZZ4 short block, auto camaro = 342rwhp, 352rwtq (comparison to siamesed tpi) http://www.eecis.udel.edu/~davis/z28...age021105.html
i don't like to call out names, but ...
NOT STOCK, you need to relax... just cuz someone logged on twice and didn't answer your question to YOUR satisfaction you throw the BS flag?? not good etiquette... we're not all here to serve your needs. maybe you could have sent him a much more polite personal e-mail requesting more info on R&D and testing procedures?? or even a more polite post requesting the same info??
all grumpy is claiming is that he has made a box that will perform similarly to the box that the stealth ram comes with, but will fit under the stock hood.
how much testing does that really require? a dyno comparo would probably be great, but he already said his dragstrip times were similar with both boxes and a lot of serious drag racers put more faith in times than dyno numbers.
i think it's great that someone took their own time to attempt to develop something that corvette owners have obviously shown an interest in. Holley won't develop one for us, betchya that!
grumpy, i also agree with some of the suggestions made about how to improve your product.
i'm not surprised by grumpy's response considering his chosen forum name and NOT STOCK's attititude!! (except i'm not sure if grumpy refers to his demeanor or his vettes? haha). i'm sure that in the future he will attempt to be more "businesslike" and "professional", as well as become a supporting vendor if he is not already.
should we consider how "unprofessional" it seems to comment on someone elses post about their product while stating that you are attempting to develop a similar product. darn tootin that is a conflict of interest! you probably shouldn't comment on this post, on grumpy's product, and if you want to determine the demand for another TPI manifold, or "advertise" it, you should probably start your own post (after becoming a supporting vendor, of course)
WHEW, I LOVE this forum and it has a LOT to offer!! i had to comment cuz i really don't like to see things degenerate this way. let's all try to be civil here?? maybe i'll start a basic rules of etiquette post for people to refer to when in question??
ok, am i gonna get flamed for some reason?? :D :D :rant:
Personally, I fear the stealthram won't be such a great street-rod intake given the high rpm powerband (that and I have an auto, low rpm motor)... but for the strip it sure looks promising. Thanks to Grumpy for taking the initiative as Im positive there is a definitive niche for the modified plenums. I'm sure once these start showing up under other members' hoods without complaint, that a lot of the questions will dissipate and these puppies will really start to sell. GRUMPY: When's the IPO?
:cheers:
I've noticed several folks wondering about the low-end torque or "streetable" nature of this intake. I'm putting this intake on my 427. If I were starting to build my engine from scratch right now, it'd probably be a 454. My engine is built using an aftermarket Dart block. You know you can get aftermarket small-block blocks now with 4.25" bores? My engine is a 4.0" stroke. Combine my stroke with that bore and it's a 454. Now, think about airflow with that intake if it's on a 454. I'm not saying everybody has to go out and build a super-stroker, but more folks are starting to "pull out the stops" and buy aftermarket blocks to build their engines. When you do that, there's sort of no reason to build anything less than a 454 small-block. When you think of it like that, this is the type of intake you want. Anything less would be too restrictive on the top-end. "just my opinion" :seeya
(not bashing at the product, just the post)
Later :cheers:
I agree, No PAY, No PLAY. Mods what the deal with this one, uh?
Later :cheers:
