Made for you Looms?
Old Mar 20, 2003 | 01:18 PM
Strick's Avatar
Strick
Default Made for you Looms?
Anybody install the Made For You plug wire looms on your LT-1? What wires did you use? Where the stock lengths okay or did you have to make your own wires? Seems like I'm the only one with this problem :rant:
Strick :rolleyes: :crazy:
Old Mar 20, 2003 | 02:07 PM
OleDog's Avatar
OleDog
Default Re: Made for you Looms? (Strick)
Sorry Strick, I've got an L98. The "Made For you" Looms are great. Got one side on,so far working on the drivers side right now. Bought STOCK red Taylor Spiral pros here on the forum got the looms from Summit. Made sure the nuts are stuck good in the looms, I lost one and couldn't find it , bought another nut and glued it in.
PS do a search.
Old Mar 20, 2003 | 02:11 PM
Strick's Avatar
Strick
Default Re: Made for you Looms? (OleDog)
PS do a search.
What size wires are you using 8mm or bigger?
Old Mar 20, 2003 | 02:23 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I have them on my IROC along with MSD 8.5mm SuperConductor wires from Summit. The looms required a little machining to fit the wires but work vey well.
On the Vette I run TPIS 8.0mm wires with stock looms.
Old Mar 20, 2003 | 02:27 PM
Strick's Avatar
Strick
Default Re: Made for you Looms? (65Z01)
I have them on my IROC along with MSD 8.5mm SuperConductor wires from Summit. The looms required a little machining to fit the wires but work vey well..
When you say machining, do you mean you drilled/reamed them to fit?
Old Mar 20, 2003 | 02:32 PM
scorp508's Avatar
scorp508
I have the looms on my L98 and the MSD 8.5mm wires fit great w/o any work to them.
Old Mar 20, 2003 | 02:36 PM
Strick's Avatar
Strick
Default Re: Made for you Looms? (scorp508)
I noticed that Made for You looms come in 7-8mm and 10.5mm. Which size did you use? :confused:
Old Mar 20, 2003 | 02:43 PM
scorp508's Avatar
scorp508
The ones that say they fit 8mm.
Old Mar 20, 2003 | 03:00 PM
Strick's Avatar
Strick
One more thing, did you get the style that bolts to the side of the head or on top of the valve cover?
Old Mar 20, 2003 | 03:50 PM
STL94LT1's Avatar
STL94LT1
I dremmeled out my stock looms to fit Taylor Spiro Pro 8mm wires.
Old Mar 20, 2003 | 04:02 PM
Strick's Avatar
Strick
Default Re: Made for you Looms? (STL94LT1)
There just isn't enough room for these wires to fit in the stock clips even if it were reamed out. Hind sight seems to be stay with stock size wires. :sad:
:flag :flag :flag
Old Mar 20, 2003 | 04:55 PM
TA's Avatar
TA
Here's a pic of them on my car. They fit perfectly and really clean up the routing of the wires.
Old Mar 20, 2003 | 06:06 PM
Strick's Avatar
Strick
Default Re: Made for you Looms? (TA)
Thanks for the pic. :cheers: This is why I want them on my LT-1, they look great. BTW, your engine looks like I want mine to look--clean and organized. BUT, I can't get the answer to the question,"Will the stock length wires be long enough for these looms on the LT-1?"
Thanks again :banghead: :banghead:
Old Mar 20, 2003 | 08:29 PM
LD85's Avatar
LD85
Got the web site link for the looms?
Old Mar 20, 2003 | 10:14 PM
Strick's Avatar
Strick
Default Re: Made for you Looms? (ld85)
You can look under thunder racing on the column to your left. Or you can go direct to http://www.made4uproducts.com :thumbs:
Strick :flag :flag :flag
Old Mar 20, 2003 | 10:41 PM
Strick's Avatar
Strick
:hurray: :hurray: :hurray: :hurray: :hurray:
I just got an e-mail direct from Made For You Products by a guy named Ross. He says my MSD 8.5mm wires will work with their (50-756) verticle looms, length and thickness. I order tomorrow am!
I've been looking for this answer all week. I'm excited! :hurray: :hurray:
Hopefully I'll have pics when I'm done. Thanks for all the replies :cheers:
Happy Strick :hurray: :flag :hurray: :flag
Old Mar 20, 2003 | 10:54 PM
ittlfly's Avatar
ittlfly
They will work as long as you aren't running headers on the LT-1. If you are..... let me know what you come up with as I've been beating my head against a wall on this one.
[Modified by ittlfly, 7:55 PM 3/20/2003]
To Made for you Looms?
Old Mar 21, 2003 | 10:38 AM
Strick's Avatar
Strick
Default Re: Made for you Looms? (ittlfly)
Well, I've got The Hooker Shorties and it appears they should work better than the factory set up. I'm concerned about the AIR pipe on the pass side, go under or over? Are you using the verticle loom set attaches to the head, or the ones that attach to the valve cover bolts?
Now I have to find who sells them. Just found them from Thunder Racing, a little expensive @ $61.89! :crazy: :bb
Strick (Where is the smile face robbing a bank?)
[Modified by Strick, 4:00 PM 3/21/2003]
Old Mar 21, 2003 | 11:45 AM
Strick's Avatar
Strick
Okay, I've done it, I've ordered the Made For You looms and brackets. I will be the test guy for all you LT-1 guys on this venture. :yesnod: :yesnod:
Is it time for a beer yet? :cheers:
Old Mar 21, 2003 | 03:02 PM
ittlfly's Avatar
ittlfly
Strick :flag :flag :flag [/QUOTE]
It may be after you get done with this install. :jester Maybe you could post a pic or two after.
