Made for you Looms?
Old Mar 21, 2003 | 03:10 PM
Strick's Avatar
Strick
Default Re: Made for you Looms? (ittlfly)
It may be after you get done with this install. :jester Maybe you could post a pic or two after.
I'm planning on it. I'll do a report on the looms and take pics along the way. Now I have to wait until Tuesday til I get them. :cuss
While I got you here, plug wires, which plugs do the straight boots go on?
Old Mar 21, 2003 | 04:55 PM
ittlfly's Avatar
ittlfly
Default Re: Made for you Looms? (Strick)
I've had to put mine on # 8 only due the JBA shortys. Had to route it to the plug placing the wire from underneath. Maybe someone will jump in here with a stock set up.
[Modified by ittlfly, 1:56 PM 3/21/2003]
Old Mar 21, 2003 | 05:33 PM
Strick's Avatar
Strick
Thanks ittlfly. I guess that's where they belong. I'll put a little something on the wire so it doesn't wear through.
THANKS GUYS :cheers: :cheers:
Old Mar 21, 2003 | 05:34 PM
LD85's Avatar
LD85
Anyone using plug wire insulators?
Old Mar 21, 2003 | 05:42 PM
Strick's Avatar
Strick
Default Re: Made for you Looms? (ld85)
I have a set of Taylors, but they rest right on the header (just on 6 & 8). I chose another route.
Old Mar 21, 2003 | 06:18 PM
LT-4 CE's Avatar
LT-4 CE
From: Everyday you must choose between the pain of discipline and the pain of regret. Fredericktown, OH
These are really a nice product, had some on my street/strip Nova. They really look good. I think others have mentioned it too, but I was runnin 8.8 wires, so I had to drill out 8mm looms. I thing I found out is that you do not want to drill the holes too big, they need to clamp down snuggly on the wires or the wires will slide around. This could allow them to hit your exhaust.
Regardless, I liked them and am considering them for my LT-4.
Old Mar 21, 2003 | 06:50 PM
cprgmr's Avatar
cprgmr
I'll be looking forward to the LT1 pics, that's for sure! :)
Old Mar 23, 2003 | 01:34 AM
ninetyfivevette's Avatar
ninetyfivevette
Default Re: Made for you Looms? (cprgmr)
I have them on order for my LT1.
Will stock length wires work, or does a person have to get a "cut-your-own" set?
Old Mar 23, 2003 | 07:42 PM
Strick's Avatar
Strick
Default Re: Made for you Looms? (ninetyfivevette)
Boy, this is the question I have worked on for almost a week. Finally, I got an e-mail right from Made For You. Ross (the Made For You tech) told me the verticle looms with the head mounted brackets will work with stock length cut wires. I'll tell you Tue when they arrive.
Strick :flag :flag :flag
Old Mar 23, 2003 | 09:07 PM
ninetyfivevette
Glad to hear it. Thanks for the reply.
