optispark help
Old Mar 20, 2003 | 11:31 PM
Vette 89's Avatar
Vette 89
Default optispark help
Just washed the engine in my 93 must have got water in the optispark as it does not want to start. I am in no hurry for the car, my question is will it dry out if I leave it long enough.
Old Mar 21, 2003 | 12:21 PM
Vette 89's Avatar
Vette 89
Default Re: optispark help (Vette 89)
ttt
Old Mar 21, 2003 | 01:03 PM
fasteddez's Avatar
fasteddez
it may...if you can, try drying it with a hair dryer or something of that nature to speed up the process...nothing too hot though it is only plastic.
Old Mar 21, 2003 | 02:49 PM
C4Crazy787's Avatar
C4Crazy787
Default Re: optispark help (fasteddez)
:iagree: If you live in a dry climate set a fan in front of the car and pop the hood. But depending on the opti's mileage it may be time for a new one.
I replaced mine @ 42k and was suprised at the terrible condition of the inside of the unit (oily & rusty). Good Luck :seeya :flag
Old Mar 21, 2003 | 03:03 PM
Strick's Avatar
Strick
Default Re: optispark help (C4Crazy787)
Ditto for me. I had 50k on mine and it was still running fine. But when I took a look on the inside I was horrified at the water, rust, and dirt all over the inside :crazy: :crazy: I could have been on the hook somewhere on the road! :bb :bb
My advice: bite the bullet and take it (opti-spark) off and replace it and VENT it. :yesnod: :yesnod:
Old Mar 21, 2003 | 03:31 PM
PurpleC4's Avatar
PurpleC4
Cruise-In I Veteran
Cruise-In II Veteran
Currently Corvette-less
Default Re: optispark help (Strick)
Inevitably ~ you will have to replace the OptiSpark if you plan to keep the Vette. However ~ sometimes the budget can't absorb the hit at the present time, so try this as a stall tactic:
Go to a computer supply store and buy a couple of cans of compressed air. You know ~ the type that you use to clean the boards inside the computer.
Attach the plastic tube, and climb under the front of the engine and work the can close enough to the OptiSpark to insert the plastic straw into one of the vent holes on the bottom of the Opti. The dry air in the can will blow out the moisture and dry out the inside of the OptiSpark unit.
~ Purp :thumbs:
Old Mar 21, 2003 | 03:34 PM
Strick's Avatar
Strick
Default Re: optispark help (PurpleC4)
~ Purp :thumbs:
Hey Purp good idea :iagree: :iagree: :thumbs:
Old Mar 21, 2003 | 03:44 PM
PurpleC4's Avatar
PurpleC4
Cruise-In I Veteran
Strick ~
Experience is the best teacher. :cheers: Been-there Done-that! :steering:
~ Purp
Old Mar 21, 2003 | 05:39 PM
Strick's Avatar
Strick
Strick ~
~ Purp
You know, wouldn't it be neat to make a book from some of the really creative ideas that float along this forum. HMMMMMM :chevy
Strick It's beer thirty here :party:
Old Mar 21, 2003 | 06:17 PM
Vette 89's Avatar
Vette 89
Thanks for all the suggestions, I'l give them a try this weekend. The car has only got 7000 miles on it, and the intake manifold gasket is leaking quite bad that is the reason I was washing the engine before I tear it apart to fix it.
Old Mar 21, 2003 | 06:34 PM
92PoloVette's Avatar
92PoloVette
CI 6-7-8-9 Veteran
I say if you're going to take the intake off any way. Just go ahead and change the OPTI. (That is if there is any way you can afford to).
:yesnod:
To optispark help
