1995 distributor problem,,,please input any information
Old Mar 23, 2003 | 12:05 PM
VetteFever29841's Avatar
VetteFever29841
1st Gear
Default 1995 distributor problem,,,please input any information
On my 1995 vette, i changed the spark plugs and then began to change the wires, when I pulled the wire off the distributor I found oil all over the end of the spark plug wire that goes into the distributor,,This is a bad thing, Right?
Why is there oil there, and how do you fix it.
Old Mar 23, 2003 | 12:11 PM
STL94LT1's Avatar
STL94LT1
Default Re: 1995 distributor problem,,,please input any information (VetteFever29841)
Check the front of your intake, it may be leaking.
