89 corvette starting problems
Old Mar 24, 2003 | 10:35 PM
Jack B's Avatar
Jack B
Default 89 corvette starting problems
I have a stock 89 that either starts and runs perfectly or starts and loses R.P.M. 's immediately and dies. It can d this whether the engine is cold or hot.Would the cold start valve and IAC valve be the best place to start looking Some times it will start and run immediately after it starts and dies and other times I have to wait. Good to be back on the forum. My son graduated from college so I got my compute back. Thanks for any help.
Old Mar 24, 2003 | 10:57 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: 89 corvette starting problems (Jack B)
Your '89 Vette doesn't use a cold start valve; instead the ECM handles cold start enrichment through the 8 regular injectors.
Pull the IAC and clean the pintel and bore with some TB cleaner; also clean the TB & throttle plates.
Then reset the base idle and TPS base value, my method is on my site.
