Idel Speed 88 Corvette
Old Mar 27, 2003 | 06:33 PM
Bobmillert31's Avatar
Bobmillert31
Default Idel Speed 88 Corvette
I know the computer is supposed to controls the idel speed. The manual says the speed should be between 400-450 RPM. Seems to slow to me. What should the speed be out of gear with an auto tran? Is there a procedure to set the speed from scratch?
Old Mar 27, 2003 | 07:02 PM
vader86's Avatar
vader86
Default Re: Idel Speed 88 Corvette (Bobmillert31)
Mine idles at about 6-700 rpm in drive, and about 7-800 in park.
There is a procedure for setting the TPS correctly, on 65Z01s site.
Old Mar 27, 2003 | 07:05 PM
don hall's Avatar
don hall
Idle speed for an '88 with stick or auto is 450 RPMs. You will need two special tools:
balance manometer (J-23951) and idle air valve plug set (J-33047), and instructions. It might be best to have an experienced tech do the work.
Old Mar 27, 2003 | 07:11 PM
FlyboyZR1's Avatar
FlyboyZR1
https://www.corvetteforum.com/techti...D=55&TopicID=2
Old Mar 27, 2003 | 07:13 PM
ANTI VENOM's Avatar
ANTI VENOM
Default Re: Idel Speed 88 Corvette (Oldman)
I would guess that it would be around 750 rpm. My first question is: what is your idle speed. Second: What is going on that you need to adjust your idle. Maybe there is a problem.
Old Mar 27, 2003 | 11:00 PM
Sam Lam's Avatar
Sam Lam
I have a 89 coupe and the idle adjustment is very easy......if you can follow a procedure. You need a tach, voltmeter and that is about it. It is a good idea to set the timing before you make this adjustment. Email me if you want a procedure. I use the procedure as described in the Helms manual. Regards, Sam
Old Mar 28, 2003 | 09:31 AM
OleDog's Avatar
OleDog
Default Re: Idel Speed 88 Corvette (Sam Lam)
Bob, search for the procedure to do the Idle Air Control valve(IAC). No special tools needed just a paper clip. While your at it buy some throttle body cleaner and clean that TB. When you get around to it do the TPS you'll need a good voltmeter for that.
Old Mar 28, 2003 | 10:58 AM
Bobmillert31
Thanks for all the HELP. I should should be able to make the adjustment now. The reason I need to do the adjustment is the pervious onwer instead of maintaining the car just adjusted the idel set screw on the TB to correct any problems.
Old Mar 28, 2003 | 04:33 PM
VetBoy89's Avatar
VetBoy89
The 400-450 is your "base" idle, that's with the timing wire unplugged. After you set it and plug the wire back in your idle should be between 600-700.
To Idel Speed 88 Corvette
