Anyone have experience or used B&M Trick Shift ATF??
I don't know from fact, but I was told B&M Trick shift ATF fluid is the same as Ford ATF fluid. I've been running Ford ATF fluid in my Corvette for the past 7 or 8 years with no adverse affects. It's cheaper than B&M, and works just fine in my 700R4 so I'll stick with it.
I'm sure you'll get more responses so you and I will learn more about it.
