17x11 wheels
Old Mar 30, 2003 | 05:27 PM
snake killer's Avatar
snake killer
Default 17x11 wheels
I'm thinking of putting 17x11 wheels on the rear of my '93 vette. Has anyone done this? Is there anything I should Know? What about the offset - do you go with Gran Sport wheels?
Old Mar 30, 2003 | 05:39 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: 17x11 wheels (snake killer)
I went with AFS 50mm offset, they fit fine. www.afswheels.com
Old Mar 30, 2003 | 06:20 PM
The Bus's Avatar
The Bus
Default Re: 17x11 wheels (Mr Mojo)
I use the ZR1 wheels {36mm offset } for autocrossing with 315 35 17 tires with no rubbing on all four wheels. The tires do stick out past the rear wheel well about an inch which is what I wanted.
Old Mar 31, 2003 | 10:15 AM
The Bus's Avatar
The Bus
Default Re: 17x11 wheels (The Bus)
You ask for pix of wheels on car. The only pix I have is from a distance and details can not be seen. I use R compond tires on the wheels just for autocrossing and pull a small trailer to haul them. The first autocross for the season is next weekend; and if you want a close up shot of wheel and fender I'll take the camera along and take pixs after I mount them for the event.
Old Mar 31, 2003 | 10:45 AM
NavyVet's Avatar
NavyVet
I run 315s front & rear for autocross/track events. I use the GS (50mm) offset and have no clearance problems - they don't stick out much at all - actually the more negative camber you run, the less they stick out at the top of the wheel well :flag
Old Mar 31, 2003 | 10:54 AM
Garys '92 LT1's Avatar
Garys '92 LT1
Yes, I put the 17 X 11's on the rear on my 92 LT1 and they look great... The 315 GS tires stick out about 1" on either side, but the rear view is awesome... I have not experienced any rubbing yet, but that's not to say it wont... but the look and the ride is really what I wanted...
Gary :flag
edit: Oh BTW, I have the 36mm offset wheels.... If you want the tires completely under the wheel wells, get the 50mm offset wheels... :steering:
[Modified by Garys '92 LT1, 5:30 PM 3/31/2003]
To 17x11 wheels
