Opti Spark
Old Mar 31, 2003 | 09:55 AM
bwagner's Avatar
bwagner
Default Opti Spark
Anyone have an tip on replacing one? Not repart it but replacing it. Any adjusting that needs to be done when replace it? And what all should I get to replace one. I'm being told like there's two different parts of it I need. I don't care about doing the venting on it as I'm just fixing it and trading it in on a C5.......any help would be helpful!!! :cheers:
Old Mar 31, 2003 | 10:33 AM
Strick's Avatar
Strick
Default Re: Opti Spark (bwagner)
If you are just trading it in, do they know about the opti problem? If not, go ahead and trade it in. if there is a opti problem, and they know about it, the cheapest way to fix might be to just replace it with an Auto Zone special. But, there is no cheap way to replace the ole opti-spark, it's the labor. Now if you are doing it yourself................................ lots of help right here.
Good luck with your C-5 :skep:
:flag :flag :flag
Old Mar 31, 2003 | 11:38 AM
John Row's Avatar
John Row
Current cheapest place for new opti...
Jason @ Sam Taylor Chevrolet 850-243-8826
Cost for the 94 New AC/Delco Opti-spark was $280.00 + Shipping
Old Mar 31, 2003 | 11:48 AM
Vette 89's Avatar
Vette 89
Default Re: Opti Spark (John Row)
Is that price just for the opti or does it include cap & rotor, I also take it that it is a genuine GM part
Old Mar 31, 2003 | 12:01 PM
John Row's Avatar
John Row
Default Re: Opti Spark (Vette 89)
Complete opti.
Yes.
Credit for the number goes here: http://forums.corvetteforum.com/zerothread?id=526871
[Modified by John Row, 11:03 AM 3/31/2003]
Old Apr 1, 2003 | 07:27 AM
bwagner's Avatar
bwagner
Default Re: Opti Spark (Strick)
:flag :flag :flag
No one knows about it but as soon as you get in the car and start it up the engine light come on and it runs like crap. Can't go trade it in running like that. Now the one that Auto Zone cares is it the complete thing. So if I call and ask for an opti spark is that all I need? I'm hearing different things, like cap and rotor as well.......
Old Apr 2, 2003 | 02:09 PM
John Row's Avatar
John Row
Be sure it's the complete opti for a 94 LT1 (95-96 are something like $100 cheaper). I priced an opti at Autozone some time ago, and I thought that it was either a base or cap and rotor, not the whole thing.
If you want to be nice to the new owner, a new water pump would be good. Even if you don't do the pump, you will need the water pump gaskets.
If you want to be especially nice, split the new opti open and put a nice seal of hi-temp RTV. Doesn't take long to do and it's not expensive.
Old Apr 2, 2003 | 02:49 PM
bwagner's Avatar
bwagner
The water pump was just done about alittle over a year ago. So I should be ok on that.
Old Apr 2, 2003 | 04:34 PM
C4Crazy787's Avatar
C4Crazy787
I could never get the balancer off the hub, but you don't have to. I just pulled the hub out far enough to remove the opti ( I have my own puller). I also heard that you can losen the balancer bolts one turn, then run the engine. I guess the belt losen's it up. Good Luck. :seeya :flag
[Modified by C4Crazy787, 4:35 PM 4/2/2003]
Old Apr 2, 2003 | 10:13 PM
fsr402's Avatar
fsr402
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Default Re: Opti Spark (C4Crazy787)
For this go under the car and with a piece of wood and a hammer it comes right off...
Now for the Opti, heck go on ebay and get a used one if your just getting rid of it and don't care to be nice to the next guy... If not get one from Jeff Kopps or that other guy that was posted here.. Changing it is not that big of a ordeal I just did it, for me getting the Rad. out was the hardest.. You could do it in a 8 hour time if you know how to get the things out.. Oh and make sure you remember the order that you take things out and put them back in the opp. or you will be taking things out again.. <Mental note the fans have to go in then the Rad.> :smash:
Old Apr 3, 2003 | 07:36 AM
bwagner's Avatar
bwagner
Default Re: Opti Spark (fsr402)
I had dropped off my car yesterday to the mech and he stated that it was throwing the high resolution code. So I ordered an optic spark from Jason. I got it tax and shipping for $304.80. In another post I read another guy just bought one from Jeff for $337.00....either one, they were both good deals. So I will be hitting it this weekend and keeping in mind every tip you guys have been giving me. :cheers:
Old Apr 3, 2003 | 10:36 AM
John Row's Avatar
John Row
A tip: After you get the new opti installed, start the engine. You can safely run it for 30 seconds or so at idle without everything attached. Listen for misses or rough running (e.g. wires crossed), etc.
Old Apr 3, 2003 | 10:37 AM
bwagner's Avatar
bwagner
But if everything goes on right I shouldn't have any problems??????
Old Apr 3, 2003 | 10:48 AM
John Row's Avatar
John Row
You shouldn't have any problems. Another tip: Don't force the opti. I slides right on if it is in the correct position. You'll see a little white dot on the opti shaft that has the keyed spline.
If you've never worked on the front end of the engine, you will spend most of your time scratching your head thinking "How the HELL do you get a wrench on that!", rest assured, you can get a wrench on everything... somehow.
Old Apr 3, 2003 | 10:52 AM
bwagner's Avatar
bwagner
I've read that a lot of people take of the radiator, is that a must?
Old Apr 3, 2003 | 10:55 AM
Rick93Z07's Avatar
Rick93Z07
heck no. I had no reason to remove it.
Old Apr 3, 2003 | 10:58 AM
bwagner's Avatar
bwagner
Default Re: Opti Spark (Rick93Z07)
That's good to hear. What was the worst set back doing yours?
To Opti Spark
Old Apr 3, 2003 | 11:00 AM
John Row's Avatar
John Row
Doesn't help a bit. Only do it if you want to clean it.
Old Apr 3, 2003 | 11:01 AM
John Row's Avatar
John Row
I wrote up a step-by-step from the last time I did the job. I can send you a copy if you want it.
Old Apr 3, 2003 | 11:04 AM
bwagner's Avatar
bwagner
Sure I'll take it, I IM`ed you with my email address...thanks!
