Door panel removal
Old Apr 1, 2003 | 09:13 PM
EBrown's Avatar
EBrown
Default Door panel removal
How hard is it to remove the door panels to get at the Bose speaker and amp. My driver side speaker is just about shot, I would like to take it out but that door panel looks intimadating :cuss
Old Apr 1, 2003 | 09:46 PM
bogus's Avatar
bogus
Default Re: Door panel removal (EBrown)
it should not be too bad...
check for screws around the grab handle, speaker grill (not sure) and edges.
Also, there may be a screw under the lens in the door light.
I don't remember the door panels for the early C4 interiors... just feel it out. You will also find spring clips and/or plastic fasteners.
it should not be very hard.
Old Apr 1, 2003 | 10:25 PM
6spd89's Avatar
6spd89
Cruise-In II Veteran
Default Re: Door panel removal (bogus)
Yes as was said 4 or 5 on bottom of panel,one for door pull,two for grab handle and 4 for speakergrill,one on side towards back of panel.
Pull up and slightly forward towards front of car watching the lock and the door handle. Remember to hook up your wires before reattaching.
Matt
Old Apr 2, 2003 | 01:20 PM
Bodhi's Avatar
Bodhi
Default Re: Door panel removal (6spd.89)
http://forums.corvetteforum.com/zerothread?id=399810
I love the "search" botton :D
To Door panel removal
