96 Sawblades.....
Old Apr 3, 2003 | 05:58 PM
Vmc's Avatar
Vmc
Default 96 Sawblades.....
Can somebody tell me if the stock configuration for an RP. LT4 was 17X9.5 all the way around?
I can't find info on it anywhere....
Thanks Guys!! :cheers: :cheers:
:seeya
[Modified by DCTC, 5:59 PM 4/3/2003]
Old Apr 3, 2003 | 06:13 PM
Gary04Z06's Avatar
Gary04Z06
Default Re: 96 Sawblades..... (DCTC)
From what I under stand, the Z51 suspension option gave you the 9.5 on all four cornors.
Check here for more info: http://corvetteactioncenter.com/tech/c4/susp_chart.html :cheers:
Old Apr 4, 2003 | 12:22 AM
_freakmonkeydogboy_'s Avatar
_freakmonkeydogboy_
Default Re: 96 Sawblades..... (Gary96LT4)
the Z51 suspension option gave you the 9.5 on all four corners
:withstupid: LT4 had nothing to do with wheels size... :D
Old Apr 4, 2003 | 03:15 AM
VETTENV's Avatar
VETTENV
Cruise-In V Veteran
Cruise-In VI Veteran
Corvette Black Book says 17x9.5 all around. GS's are the only car that had the factory 17x11's. :D
Old Apr 4, 2003 | 04:04 AM
JoBy's Avatar
JoBy
http://w1.601.telia.com/~u60113743/corvette_wheels/
Grand Sport convert has 8.5" front and LT4
1993-1996 (base)
front 17"x8.5" 56mm
Goodyear Eagle GSC, P255/45ZR-17
rear 17"x9.5" 56mm (7.4" backspacing)
Goodyear Eagle GSC, P285/40ZR-17
1996 (z51)
front & rear 17"x9.5" 56mm (7.4" backspacing)
Goodyear Eagle GSC, P275/40ZR-17
1996 Collectors Edition (base)
front 17"x8.5" 56mm
1996 Collectors Edition (z51)
1996 Grand Sport (coupé)
front 17"x9.5" 56mm (7.4" backspacing)
rear 17"x11" 50mm (7.93" backspacing)
Goodyear Eagle GSC, P315/35ZR-17
1996 Grand Sport (convert.)
front 17"x8.5" 56mm
Goodyear Eagle GSC, P255/40ZR-17
Old Apr 4, 2003 | 02:32 PM
TravisD's Avatar
TravisD
Non-Z51 got 8.5" Fr / 9.5" Rear. Z51 got 9.5" Front and Rear.
Old Apr 5, 2003 | 10:28 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
My base-suspension LT4 has 17 x 8.5 fronts, 17 x 9.5 rears.
Larry
code5coupe
:seeya
Old Apr 5, 2003 | 11:21 AM
RadPolo96's Avatar
RadPolo96
Default Re: 96 Sawblades..... (rocco16)
Larry
code5coupe
:seeya
I think that was true of all 96 vettes, thats what mine came with.
Old Apr 5, 2003 | 12:16 PM
Torch Red's Avatar
Torch Red
St. Jude Donor '09
Yes 9.5 all around on Z51 only ... weather it has LT1 or LT4.
To 96 Sawblades.....
