Pro topline heads opinions......
Old Apr 3, 2003 | 08:15 PM
black85vette's Avatar
black85vette
Default Pro topline heads opinions......
What does every one think of these heads? pros and cons.... opinions
Old Apr 3, 2003 | 10:03 PM
LD85's Avatar
LD85
Default Re: Pro topline heads opinions...... (black85vette)
what are your goals and what is the motor combo for your plan?
Old Apr 3, 2003 | 11:43 PM
black85vette
Default Re: Pro topline heads opinions...... (ld85)
goal- 350 hp- mild upgrade- am considering silvolite H 3437 pistons that will spec out at 9.8 cr with these heads, they will have 2.02 intake 1.600 exhaust valves 67cc chambers 170cc ports. 218dur .444lift hyd flat tappet comp cams grind.
I will be installing long tube headers also.
how does it sound so far? am I on the right track ?
what would you change ?
To Pro topline heads opinions......
