help with hp #'s.......
Old Apr 4, 2003 | 12:15 AM
blue72lt4sc's Avatar
blue72lt4sc
Default help with hp #'s.......
ok......in the real world what have you guys seen in way fof hp #'s at the flywheel with these common engine set ups:
1.....vette lt1 with lt4 hot cam kit and basic ecm reprogram
2.....vette lt1 with lt4 hot cam kit and lt4 heads intake and 52 mm throttle body and basic ecm reprogram
3.....vette lt1 355cubic inch with lt4 hotcam kit, lt4 heads, lt4 intake, 52 mm throttle body and basic ecm reprogram
im thinking of doing this with my 94 :chevy :flag
Old Apr 4, 2003 | 10:10 AM
1996man's Avatar
1996man
Default Re: help with hp #'s....... (blue72lt4sc)
well seeing as how my car has all of that minus 5 inches and a hotcam i would guess about 310-315 rear wheel..... just my two cents but probably a little bit more
Old Apr 4, 2003 | 12:22 PM
gbfan10's Avatar
gbfan10
Default Re: help with hp #'s....... (1996man)
Nate Plemons, has done some really good dynoing after a lot of his upgrades, I would try and check with him.
Old Apr 4, 2003 | 02:23 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
~305 Rwhp, computed using 15% loss comes to about 358 flywheel.
330 rwhp with no head porting, computes to around 390 fwhp.
Pretty much the same as #2 + ~5 rwhp.
Port the heads and these numbers all change for the better. You can add anywhere from 30-50 rwhp for ported heads depending on the port job.
[Modified by Vette92, 1:24 PM 4/4/2003]
Old Apr 4, 2003 | 02:43 PM
blue72lt4sc
Default Re: help with hp #'s....... (gbfan10)
thanks for the replies so far....i was just wondering. i read an article in chevy high performance a couple of years ago when they took a f-body lt1 and installed the hot cam kit, lt4 heads, lt4 intake, bbk 52mm and shorty headers and they claimed to get 425hp at the flywheel after ecm reprograming, and i wasnt sure how realistic those #'s were with that combo....my goal with this engine combo is 450-475 hp........thats still nice and drivable, id rather not go to stroking this particular build up...i have a sc 396 im building for my 72...id like to build a 355......who on here is making 450hp at the flywheel with a street happy 355 lt1 :chevy
To help with hp #'s.......
