Quick hypertech question.
Old Apr 4, 2003 | 06:30 PM
MagikDraggin's Avatar
MagikDraggin
Cruise-In IV Veteran
Cruise-In V Veteran
Default Quick hypertech question.
Is the hypertech controller the same for 94 thru 96 LT1's?
If not, what other years will work on my '96?
Old Apr 4, 2003 | 07:05 PM
C4kid94's Avatar
C4kid94
Default Re: Quick hypertech question. (MagikDraggin)
im almost positive 94'and 95's are the same, the 96' is differnt
Old Apr 4, 2003 | 07:09 PM
Phil-tha-Rush's Avatar
Phil-tha-Rush
Default Re: Quick hypertech question. (C4kid94)
:iagree:
yes..96s are a year to themselves :seeya
Old Apr 4, 2003 | 07:57 PM
MagikDraggin
Cruise-In V Veteran
Default Re: Quick hypertech question. (Phil-tha-Rush)
Thanks guys, that's what I suspected.
There are two controllers on Ebay, one says it's for an 94-96 LT1 and the other says it's for a 96 LT1/LT4
The way I understand it, even the LT1's and the LT4's require a different controller. Just can't trust anybody can ya?
So now there's one that says it's good for a 96/97 LT1. Is that legit?
Karl
Old Apr 4, 2003 | 09:58 PM
Lone Ranger's Avatar
Lone Ranger
For a 1996 LT1 Corvette you will need to get part number 365762, cannot substitute the 96/97 Camaro/Firebird one :nono:
See this chart and parts compatibility list:
http://www.hypertech.com/gmfeaturechart.html
[Modified by Lone Ranger, 8:59 PM 4/4/2003]
Old Apr 5, 2003 | 01:31 AM
MagikDraggin
Cruise-In V Veteran
Default Re: Quick hypertech question. (Lone Ranger)
Thanks again Lone Ranger. That's twice you've come to my rescue recently. All you guys saved me from making a stupid Ebay mistake.
Karl
Old Apr 5, 2003 | 11:35 AM
Lone Ranger
Karl
Hi ho Silver! :D
Old Apr 5, 2003 | 11:47 AM
silver & red CE's Avatar
silver & red CE
The way I understand it, even the LT1's and the LT4's require a different controller....So now there's one that says it's good for a 96/97 LT1. Is that legit?
You can program an LT4 with the f-body Lt1 programmer, an LT4 with a LT1 y-body or b-body programmer, just has to be the correct year. I think Hypertech has different part numbers to confuse the used programmer market. I think the 96/97 f-body programmer is for the 96/97 LT1/4 f-body, not sure how different it is compared to the 96 only model. I suspect a 06/97 f-body programmer will work on any 96 or 97 LT1/4 including all 96 b/f/y bodies and 97 f-bodies.
Eric
Old Apr 5, 2003 | 12:17 PM
MagikDraggin
Cruise-In V Veteran
Default Re: Quick hypertech question. (silver & red CE)
It is beginning to look like finding a controller model and year specific to my 96 LT1 vette, is like finding the old proverbial needle in the haystack.
Perusing through the Ebay listings just gives me a headache. I don't see how anybody can be certain what they are actually getting on Ebay and for 200 bucks or more, that could be a rather expensive mistake.
Seems at this point in time my best bet is to just cave in and go purchase a new one. Does anyone have any recommendations as to where the best deals may be found on one of these gadgets? MidAmerica lists them for $329, but they are on backorder.
Karl
Old Apr 5, 2003 | 12:43 PM
Lone Ranger
$300 is about as low as you'll find for a new one.
Do you have a laptop computer? If so, you can do a lot more with an AKM cable and a LT1EDIT software running on your laptop, and for less than the cost of a Hypertech:
http://carputing.tripod.com/ :yesnod:
Old Apr 5, 2003 | 01:34 PM
MagikDraggin
Cruise-In V Veteran
No laptop, no fax, just an old computer and an older Corevette, with an even older driver.
Just wantin' to get this machine in as tip-top running condition as I can before me and the wife head down to Bowling Green in May.
Thanks anyway for the tip.
Karl
Old Apr 5, 2003 | 02:38 PM
silver & red CE
Another option is to mail your PCM to a tuner and let them do it. I went to Brian at BVD Performance and he did lots more than a Hypertech can and only charged me $200. Disabled rear O2 check, disabled CAGS, retuned the WOT A/R ratio, fans, gear change, tweaked the ASR.
If you have a 96, LT1 edit cost ~$550.
Eric
Old Apr 5, 2003 | 03:18 PM
JasonL's Avatar
JasonL
Have you checked the C4 Parts section? Used HPPs pop up from time to time.
My personal suggestion would be to grab a used HPP for $200 and use it for fan settings only (maybe shift points too?). If you want more later down the road, sell the HPP for $200 :D and have the PCM custom programmed for a small fee. Or buy OBD2 LT1-edit for $550.
To Quick hypertech question.
