Options for Replacing cats with straight pipe
Old Apr 7, 2003 | 03:32 PM
MaddMaxx's Avatar
MaddMaxx
Default Options for Replacing cats with straight pipe
Is it possible to do this w/o a welder (bolt on)?
Old Apr 7, 2003 | 03:42 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Options for Replacing cats with straight pipe (MaddMaxx)
You could just cut the ends from your old cat and have a shop weld a section of pipe between them.
Old Apr 7, 2003 | 03:52 PM
MaddMaxx's Avatar
MaddMaxx
Default Re: Options for Replacing cats with straight pipe (65Z01)
I am in a area with no inspections, but the shops do not want to remove them.
Old Apr 7, 2003 | 03:59 PM
LD85's Avatar
LD85
Yeah, cut the y-pipes and you can buy two length of stright pipe that will allow you to put a clamp on each end of the pipe.
Or you can buy the "off road" straight pipe kit that goes from the front to the rear mufflers from Ecklers its in their catalogs!
Old Apr 7, 2003 | 04:55 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
It is because it is against federal law for them to.
You just need to find a racer friendly shop and make sure you tell them it is a track only car. I have race pipes which I can drop and put aftermarket cats in for "the street" ;).
To Options for Replacing cats with straight pipe
