Real nice setup!
Old Apr 4, 2003 | 09:05 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Real nice setup!
I install my New TPIS AIr Box tonight. It mounts in the same spot as the regular air box, but instead of pulling front the very small spot in the front of the box, it pulls from underneath the car. You have to cut a hole in the radiator shroud and it opens up the air box to the very underneath of the car! The air cleaner is basically on the exact opposite side as the original, if you can picture that.
Dad forgot his camera, or I would have taken some pictures. And eventually will for you all to see.
The only two snags I ran into was the aux fan in front of the radiator is mounted to the section that needs cut out. Upon inspection I was able to leave two 1.5 inch strips running from the front to the upper part of the rad shroud so the fan would still have its upper supports.
The second was the T-Bolts they supply to hold the air box in place were contacting the hood slightly. So I just replaced them with regular bolts unti the T-Bolt hold downs can be turned down a tad.
The unit is about a million times better looking than the stock air box. Its Gloss black and looks sweet.
Corky picked up .3 sec just installing that alone from the stock cut box! That is HUGE, and now that I see how its set up I can see why its such an improvement over the stock unit.
Tomorrow, provided the weather hold out, I am making my way to NJ for the first track times with the car! Its all loaded up and we are leaving at 3am for the bijillion hour trip out there :crazy:
Hope to report a good time for you all! Talk to you later, and pray the weather hold out. :blueangel: :cheers:
Old Apr 4, 2003 | 11:57 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: Real nice setup! (ski_dwn_it)
Mackey has that setup.
Old Apr 5, 2003 | 12:14 AM
MrNuke's Avatar
MrNuke
I have the SLP ram air setup and it pulls from underneath the car in front of the radiator. How does yours get all the way under the car?? Does it go behind the radiator or something?
Old Apr 5, 2003 | 01:36 AM
Ramrod92's Avatar
Ramrod92
Cruise-In II Veteran
Like this? http://temp.corvetteforum.net/c5/raysur/index2.shtml :hurray:
Old Apr 5, 2003 | 03:38 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: Real nice setup! (Ramrod92)
It pulls from right infront of the radiator actually. There is that tunnel that is just above that scoop on the front of your car that feed air to the radiator, this pull the air from there. Its supposedly pressurized due to the air hitting the radiator.
My air box looks quite a bit different than that one shown above. Its all fiberglass and doesn't have any of those support webs in it. Its quite a bit thicker at the bend too. But the concept is the same.
This is just a quick observation, and I might be all wet, as I did not even drive the car yet with the new box, but the car seems to rev ALOT quicker now. Believe me with the solid cam in there, it revved QUICK before, but now it seems to be alot snappier.
Well its time to take off for NJ. :crazy:
Old Apr 5, 2003 | 11:46 AM
fsr402's Avatar
fsr402
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Hey Ramrod92 is that your setup? If it is where did you get it?
Old Apr 5, 2003 | 12:03 PM
MrNuke's Avatar
MrNuke
Ohh ok.. then it is the exact same thing I have from SLP.. cool.. I loved mine since day one. On the highway above 40 or so she pulled noticeably harder.. :cheers:
Old Apr 5, 2003 | 01:48 PM
Ramrod92's Avatar
Ramrod92
Default Re: Real nice setup! (fsr402)
Troy, actually that is Raysur's, but it is the same one I have. I haven't installed it yet, it will be going in when I do my motor. I bought mine off the forum. I think TPIS is the only one who still carries them. :steering:
Old Apr 6, 2003 | 12:09 PM
88-406's Avatar
88-406
St. Jude Donor '05
Ski
Any new 1/4 mi numbers? How it'd do, thoughts, impressions etc...
KM
Old Apr 6, 2003 | 03:09 PM
TheCorvetteKid's Avatar
TheCorvetteKid
Default Re: Real nice setup! (88-406)
Anyone know American Performance's website? I just saw Raysur's setup (posted above at: http://temp.corvetteforum.net/c5/raysur/index2.shtml ) and it looks really REALLY sweet!!! The Mid America kit doesn't look anywhere near that good, and I can't find the TPiS one on their site.
Thanks.
Old Apr 7, 2003 | 12:24 AM
Ramrod92's Avatar
Ramrod92
Default Re: Real nice setup! (TheCorvetteKid)
Try http://www.exoticmuscle.com/webpage....&CATSEL=ENGINE and scroll down to C1425. If you decide to order from EM, let them know I sent you. :cheers:
Old Apr 7, 2003 | 04:35 PM
TheCorvetteKid
Just checked out the Exotic Muscle website. Looks like the same one as Raysur's, but it says that it'll only fit '91-'95 cars. CRAP! Mine's an '89!
I guess I'll take another look at the Mid America one. Too bad. I really like the 'factory-stock' look of Raysur's.
But thanks for the info Ramrod92.
[Modified by TheCorvetteKid, 9:36 PM 4/7/2003]
Old Apr 7, 2003 | 05:22 PM
TA's Avatar
TA
Will do...........I'll tell em Ramrod sent me :D
To Real nice setup!
