mini starter not working with flywheel
Old Apr 7, 2003 | 09:43 PM
Mike_'s Avatar
Mike_
Default mini starter not working with flywheel
I put a new starter in (mini starter) but am having trouble getting it to line up with the flywheel. I got under there and looked at the gear while somebody else started the car. The gear bounces off the flywheel.. I'm not sure why. Has anybody else ever had this problem? If I add shims, it doesn't seem to get any better.
Old Apr 7, 2003 | 10:45 PM
Hole-Shot's Avatar
Hole-Shot
Default Re: mini starter not working with flywheel (Mike_)
Double check the part number to your application. Sounds like it could be wrong. Good Luck!
