Open Air Filter lid?
Old Apr 8, 2003 | 03:07 PM
toondaddy's Avatar
toondaddy
Default Open Air Filter lid?
I have heard talk about an open/ cut air filter lid as a performance mod......it may sound a little weak, but I don't understand this just by looking at my K&N aifilter.
1. how do you do this?
2. what performance gain do you get?
Thanks in advance :thumbs:
Old Apr 8, 2003 | 03:35 PM
hngacurv's Avatar
hngacurv
Default Re: Open Air Filter lid? (toondaddy)
Your performance gain isn't going to be much, but every little bit helps. Just take your air cleaner and cut the front off of it. Leave enough to hold the air filter in place. I just used one of the bends as a straight edge and cut the rectangle out.
Old Apr 8, 2003 | 03:39 PM
Mike's 86's Avatar
Mike's 86
If you look at the stock air filter cover, it's mostly covered, when you open the cover up you cut away most of the area to alow more air through the filter, their is a slight hp gain. Hope this helps......... :cheers:
Old Apr 8, 2003 | 03:45 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
With a K&N upgrade expect about a 10hp gain.
Old Apr 8, 2003 | 05:31 PM
semvhu's Avatar
semvhu
Default Re: Open Air Filter lid? (65Z01)
Could someone post a pic of their final product? :) Sounds like an interesting, cheap mod for a little extra oomph. Thanks!
Old Apr 8, 2003 | 05:43 PM
vader86's Avatar
vader86
Default Re: Open Air Filter lid? (semvhu)
All you have to do is cut a big square hole in the air lid, so that the K&N is exposed.
We have proven gains on the L98, LT1 is a bit iffy, but it cant hurt anything.
To Open Air Filter lid?
