I want to disconnect the coil so that I can prime the oil pump without the engine running. Since the coil is built into the distribitor cap, how is this done?
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Re: Disconnecting the coil (BIG K)
I believe, to do what you are seeking, you can simply pull (gently) the white, black and brown wires ( I think those are the right colors) from the Dist Cap.
Or you could always remove the coil itself, just four screws plus the wires I mentioned.
Pull the single red wire (white clip I think) off of the cap and you'll be good to go. How are you going to prime it, using the starter motor? If so pull the plugs so that its much easier on the motor.
I guess I'm just lazy about doing more work. Doesn't the same pressure happen when it's just hard to start? Normally does't more pressure exist because of detination?
Just trying to expand my knowlege and of course not hurt the car! :yesnod:
If you pull the sparkplugs then all the air on the compression stroke will just be forced out the plug holes instead of being compressed inside the cylinder.
Scorp is right; think of the compression ratio. Compression accounts for most of the pumping work done by the motor in the compression phase of the cycle. Of course during the charge burn phase cylinder pressure takes a large jump upward.
Pull the wires from the side of the dist to prevent a spark. Also pull the two Injector fuses to prevent fuel from entering the cylinders during cranking. No need to wash them before it starts.
Thanks for the idea. How is it easier on the motor(starter?).
I think we have a mix-up in terminology. Using more traditional definitions to clarify, removing the plugs makes it easier on the engine (no pressure on rotating assy) , the starter motor is not a concern.
Give me fuel, give me fire, coming soon to an engine near you :D .
Nothing is mixed up. Removing compression from the engine will make it MUCH easier on the starter motor. The engine itself who cares it can handle it. If he's planning on running the starter motor for a while to prime the oil I'm sure it would be much happier to do it with a free spinning engine.
