rough idle
Old Apr 10, 2003 | 10:54 AM
gkron's Avatar
gkron
Default rough idle
Hello everyone,
What would cause a rough idle 30 seconds after starting the car ('92 LT1). The car tends to run rough for a few minutes right after starting as it warms up. When it reaches a certain temperature it smooths out. The car runs great otherwise. Any ideas?
Thanks,
Gary :confused:
[Modified by gkron, 10:04 AM 4/10/2003]
Old Apr 10, 2003 | 11:00 AM
Rynda's Avatar
Rynda
Default Re: rough idle (gkron)
EGR valve sticking a little?
Old Apr 10, 2003 | 01:45 PM
John Row's Avatar
John Row
Leaking injectors. Another possiblity.
Old Apr 10, 2003 | 01:51 PM
MyFatNutz's Avatar
MyFatNutz
Also, check your ground wire, may be 'cold' (oxidized).
When it was cold or damp I had an extremely poor idle, would stall when I would come to a complete stop sometimes. When the car was floored, it would completely lose power. The voltage gague would jump around. I checked every possible ground and everything seemed fine, but the ground from the battery to the engine block was green, so was the ground strap bolted to the trans bellhousing. I did not believe there was ignition problems because the opti and coil were brand new (< 1k miles).
What I did was added an additional ground, to the drivers side frame to the battery and added another on the passenger side (rear manifold stud, to the frame). Adding those grounds completely solved all the issues with the car, no jumping guages, extremely smooth idle; felt like a brand new car.
Check the grounds first, only $5 to replace. Hopefully that 's the problem.
good luck
[Modified by MyFatNutz, 6:55 PM 4/10/2003]
Old Apr 10, 2003 | 02:17 PM
gkron's Avatar
gkron
Default Re: rough idle (John Row)
If it were the injectors would there be any other signs of problems. It only happens when the car is cold and lasts for about a minute or two
Old Apr 10, 2003 | 03:36 PM
tdock's Avatar
tdock
"It only happens when the car is cold and lasts for about a minute or two"
Interestingly enough, the air pump runs for 120 seconds on start up. Might have something askew in the plumbing/check valves or the air pump itself. You should be able to hear it running, very front corner on the drivers side.
To rough idle
