Termostat gasket
Old Apr 11, 2003 | 05:37 PM
BIG K's Avatar
BIG K
Default Termostat gasket
I used a thick gasket that doesn't require liquid gasket. I torqued it to the GM specs, 25 ft. lbs. on the back side but couldn't get to the front to torque it. I had to use my best guess with open end wrench. The instructions with the gasket did NOT have any torque specs with it.
It is leaking on the front side.
Has anyone used one of these?
Sounds like my best bet is to take it off and get a $.89 paper gasket and use some permatex.
What do you think?
Old Apr 11, 2003 | 05:46 PM
weekendwrench's Avatar
weekendwrench
Default Re: Termostat gasket (BIG K)
All I have ever used are the regular gaskets and coated them with a little grease to hold it in place. I have never torqued one just tighten until snug. Make sure the surfaces are clean and flat.
Old Apr 11, 2003 | 10:54 PM
Sam Lam's Avatar
Sam Lam
I have owned SBC for many years and found that the thermostat housing bulb tends to "bow" up in the middle and down by the two bolts. I put the housing on a belt sander and take off a very small amount of aluminum to make the mating surface flat. Since I have done this, I have not had a leak. I use the thick gaskets and hand tighten to an equal torque. If you cannot find a belt sander, I will do it for you! Regards,. Sam
Old Apr 11, 2003 | 11:03 PM
ciscokid's Avatar
ciscokid
I would insure that your surfaces are clean. Use the card board gasket and apply some aviation permatex to both sides. Let it cure for 24 hours for best results. You should not have a leak. Are you sure you do not have a crack in the housing?
Old Apr 11, 2003 | 11:47 PM
BIG K's Avatar
BIG K
Default Re: Termostat gasket (ciscokid)
ciscokid, It didn't leak prior to my rebuild. I will check it though when I take it of momenarilly.
Sounds like I need to use quite a bit of RTV since the uneven surface.
Thanks for the sanding offer. If it is warped I think that I can find a way to smooth it out.
Old Apr 12, 2003 | 05:12 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Try some Permatex #2 on each side of the gasket and hand tighten evenly.
Old Apr 12, 2003 | 11:51 AM
tim87's Avatar
tim87
I couldn't get mine to seal at all using a gasket. I tried it with and without RTV (on the surfaces and gasket) in various combinations including letting it seal overnight, etc. I sanded the thermostat housing and even bought a new housing without success. Finally I did it with RTV alone (red RTV in this case but probably blue would work as well) and it sealed perfectly.
:seeya
Old Apr 12, 2003 | 02:34 PM
BIG K's Avatar
BIG K
Default Re: Termostat gasket (tim87)
Thanks tim87. I went to the extent of taking off the TBA so that I could get a streight shot at the front bolt with the torque wench. I used black RTV on both sides of the gasket. As soon as I get the timing light from a friend I will let you know what Happens. :thumbs:
To Termostat gasket
