Guess it....
Old Apr 12, 2003 | 07:38 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Guess it....
Well looks like I am gonna finally get to a track to test this engine out! Corky, Dad, and I are heading to Keystone Raceway outside of Pittsburgh for Sundays Test & Tune.
I have a few items I need to take care of tomorrow, but its all pretty easy.
Something I did want to ask if anyone knew off the top of their heads....
I have nearly a whole tank of gas 94 octane, did not think I was gonna get to a track for the next couple of weeks. Anyways I have to get all the gas out of the car so I can replace it with race gas, Corky pulls the shrader valve off the fuel rail/attaches a hose to it and then jumper his relay. Not sure if they are the same configuration, and wanted to know if anyone knew off the top of their heads how to energize the fuel pump via the ALDL. Not sure if the helms manual specifies how to do such a hing or not.
Also, what kind of times you think I'll run? If I get a mid to low 11s I will be happy. I still have to work on my exhaust and traction I think is gonna be an issue.
Talk to you all later! :cheers: :thumbs:
[Modified by ski_dwn_it, 7:39 AM 4/12/2003]
Old Apr 12, 2003 | 08:20 AM
ELEVENS's Avatar
ELEVENS
Default Re: Guess it.... (ski_dwn_it)
Ski-
I usually just siphon out the extra. It's pretty easy, and provides lawn-mower/weedwacker/leaf blower fuel.
Here' my prediction regarding ET: You'll run a sub - 11.50 :party:
...and then the track will tell you that you need a roll bar :sad: :sad: :sad: :sad:
Wish you the best, give 'er hell.
:cheers: -Bill
[Modified by ELEVENS, 8:22 AM 4/12/2003]
Old Apr 12, 2003 | 08:35 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Apply 12 volts to terminal G in ALDL Connector. Good Luck at the track!! :cheers:
Old Apr 12, 2003 | 09:41 AM
STL94LT1's Avatar
STL94LT1
Being the first time out with the new engine, I will guess 11.80.
Old Apr 12, 2003 | 09:47 AM
antenna's Avatar
antenna
12.0 even.
Good luck.
Old Apr 12, 2003 | 10:14 AM
marlon88's Avatar
marlon88
Default Re: Guess it.... (antenna)
why dont you run an external fuel pump and just suck fuel from were you fill up !! we do that several times like that ,just run a regular fuel pump with 12v and put the sucktion pipe all to the bottom of the tank and pour it into some cans !! that should work !! and you don`t have to mess with the vette !!
you should do lo 11`s :chevy good luck !!
Old Apr 12, 2003 | 12:05 PM
Hole-Shot's Avatar
Hole-Shot
What about old fashioned siphoning? All you need is a rubber hose.
As far as the ET prediction….how about a 10.9xx. :D
Good Luck!
Old Apr 12, 2003 | 12:41 PM
Ramanstud's Avatar
Ramanstud
Default Re: Guess it.... (Hole-Shot)
eehhhh......
11.25? :D
Old Apr 12, 2003 | 12:45 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Thanks guys! Hole-shot, like you prediction!
Couple of things....figured out how to get the gas out, very easy. WEnt to autozone and picked up two things. 1. shrader valve tool to remove the valve off the fuel raid, too about 1 minute. 2. 7' of transmission coolant line (guy gave it to me for free, since I am a regular :D )
Got home pulled the valve out, and pushed the 3/8" rubber tranny cooler line down over the nipple. Then ran a wire from the + terminal on the battery to the lower left most post on the Aldl. That will kick the power on to the pump. With that the gas started flowing. I had a full tank too. :rolleyes: Filled all my gas cans, till it started to sputter. Put everything back to normal.
Filled the tank with the race gas ~5gal.
Then took it down the road to my testing grounds, about 1/2 mile straight away. With the race trim on, I gave it hell after testing a few time to make sure the knock was gone. It seemed to take care of it. I ran it through the pretty much a total 1/4 but left off well before my marker when it hit 115! I still had about another couple hunder feet to go to my measured marker! And it was still pulling like I have never felt before. My 350 was lucky to hit 100 at that marked spot, so it was pretty close to what MPH the 1/4 should be with reference to mph based on the 350 setup. Its awesome to feel WOT without any detonation. :cheers: :cheers:
My AFR was just as I planned, since I could never keep it or even close to WOT to see where it was....It ran from 12.6-12.8 through the run. Pretty decent for a start.
Hope to post a good time tomorrow!
Old Apr 12, 2003 | 01:36 PM
J Z06's Avatar
J Z06
All I am saying is GIVE IT HELL!! :smash: :cheers:
Old Apr 12, 2003 | 02:17 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: Guess it.... (Jay D 90 383)
Here's the most fun way to drain the tank of gas, and pretty darn simple too.
http://temp.corvetteforum.net/c4/mrmojo2//mojo.wmv
Old Apr 12, 2003 | 02:47 PM
85vet's Avatar
85vet
Cruise-In V Veteran
Default Re: Guess it.... (Mr Mojo)
D@mn Jesse,
If not for tax season, I would be at "Pittsburgh Raceway Park" :D
ie - old Keystone raceway. To see your beast run.
Maybe next time.
Jim
Old Apr 12, 2003 | 03:46 PM
StealDads67's Avatar
StealDads67
Default Re: Guess it.... (85vet)
Let me borrow the car for the day.... Ill get rid of that gas for you :yesnod:
Prediction......11.01 <------ hehe
Old Apr 12, 2003 | 09:28 PM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: Guess it.... (StealDads67)
11:37 at 121.67 mph :cool: :cheers:
Old Apr 12, 2003 | 10:33 PM
GusBustamanteJr's Avatar
GusBustamanteJr
Default Re: Guess it.... (CORKVETTE1)
I think.....11.65 at 120
Mostly because you will be learning it again.
Maybe if you get enough runs in, you will get a 11.2 and be happy!
Then you will tune it, and tinker some more, and next week you will be consistently 11.0- 11.1!
Hows that!
Good Luck let us know ASAP!
Old Apr 13, 2003 | 07:32 PM
ELEVENS's Avatar
ELEVENS
Hey there Mr. Ski....... PLEASE TELL US WHAT YOU RAN TODAY (Sunday)!!!!
Old Apr 13, 2003 | 09:21 PM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In V Veteran
Default Re: Guess it.... (ELEVENS)
just got back from the track with ski lets just say he was flyinngggggg!!!!!! he can fill you all in with the details :cool: :cheers:
To Guess it....
Old Apr 13, 2003 | 10:08 PM
StealDads67
WHERE IS HE?!?!?!?!!?!? lol
Old Apr 13, 2003 | 10:48 PM
85vet's Avatar
85vet
Cruise-In V Veteran
Jesse,
We are WAITING on the edge of our seats!!!!!!!
Come-on - we want to know!!! :yesnod:
Old Apr 13, 2003 | 11:06 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Go check it out, Go check it out on the other post! :thumbs: :cheers:
Sorry for the delay I had to put my little boy to bed :lol:
[Modified by ski_dwn_it, 11:07 PM 4/13/2003]
