Can anybody give me all the specs fo LPE 74219 cam?
I'm asking for this because I sent e-mail to LPE regarding the shipment to Croatia, but I didn't get any anwser.
I saw on summit racing pages that they are sending to Croatia without any problem but they have only CompetitionCams.
Should I order CompCam's cam with same specs ?
They are even cheaper.
I've been shifting at 6000. The blue line is rear wheel horsepower with this cam. The car still needs lots of tuning, but it should give you an idea of where the power is. The low end torque is way off due to a seriously rich condition under 3700.
Competition Cams
Specifications:
* Advertised duration: 276 intake/281 exhaust
* Duration at .050 in. cam lift: 224 intake/230 exhaust
* Gross valve lift: .503 in. intake/.510 in. exhaust
* Lobe separation: 112 degrees
* RPM range: 1,800 to 5,800
* Best cam for modified 5.7L TPI with improved chip, injectors, plenum, runners and exhaust.
What do you think about this cam?
My goal is 450 HP (crank).
But I will go in steps:
1. -cam & heads ( stock but ported, with stock size valves )
-3-angle valve job
-siamesing plenum
-not sure about headers in this step or 2. step
2. -1.6 RR
3. -superram intake
4. -higher stall converter
Because of financial's between each step it will probably take a year or so.
My main concern is that the car will be drivable ( and faster with each step ) with stock converter untill that fourth step.
