52mm throttle body help
Old Apr 13, 2003 | 10:37 AM
vette22's Avatar
vette22
Default 52mm throttle body help
I just replaced my stock throttle body on my '87 due to bad bushings; it would never return to idle unless manually done. I replaced it with an aftermarket 52mm throttle body and now the problem is worse. I checked for binding cables and obstructions at the gas pedal without result. Any one have any ideas. Is there an idle adjustment I'm missing. Any help will be appreciated. :withstupid:
Old Apr 13, 2003 | 04:09 PM
vader86's Avatar
vader86
Default Re: 52mm throttle body help (vette22)
Check the TPS voltage, and did you clean the IAC when you put on the new TB?
Old Apr 13, 2003 | 04:28 PM
FoolCrzy's Avatar
FoolCrzy
Yes, There is an idle adjustment procedure. I can't recall it right now.. it may be in tech tips
Old Apr 13, 2003 | 07:24 PM
hngacurv's Avatar
hngacurv
Default Re: 52mm throttle body help (FoolCrzy)
After I put on my 52mm I readjusted everything. You can find a good write up with pics on TPS adjusting on 65Z01s site. Do a search on him and there you will find the link. He has a lot of other good info on there too.
To 52mm throttle body help
