Help with windshield washers.
Old Apr 13, 2003 | 07:44 PM
tikiltd's Avatar
tikiltd
Default Help with windshield washers.
I can't currently find the manual for my 88. My windshield sprayers aren't working. Is there a fuse I can check for this? (the resevoir is full.) Thanks!
Old Apr 13, 2003 | 09:47 PM
don hall's Avatar
don hall
Default Re: Help with windshield washers. (tikiltd)
Don't see a specific fuse for the washer motor. The wiper fuse is a 25 amp labled "WPR".
I'll do some research and see if there is more to check.............
Old Apr 13, 2003 | 10:20 PM
JCAIRE2's Avatar
JCAIRE2
Default Re: Help with windshield washers. (Oldman)
Hit the washer button with the hood up, while you're standing next to the washer bottle. You should hear the pump come on. Check fuse, if that doesn't work, replace pump.
Not too hard, but time consuming. Need about a foot- 18" of extensions to reach the nut on the pump, inside the washer bottle. Get another intake screen for the pump, since you will probably destroy the original, at least I did :rolleyes: I bought my parts from zip, through the forum :cheers:
To Help with windshield washers.
