stupid question
Old Apr 14, 2003 | 08:51 AM
The Hobbit's Avatar
The Hobbit
Default stupid question
Hi
Stupid question.
What is the best way (temps etc) to check the fluid level in a 700r4?
Most Euro cars are the same, start it up run it for 2 mins run through the gears put in drive and check fluid. This is obviously not correct for a 700r4 but the procedure in the hand book is pretty ‘woolly’.
What do you guys do?
Old Apr 14, 2003 | 10:07 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Default Re: stupid question (The Hobbit)
Reach normal operating temp.,put lever in each gear ending in park.Check level at idle in park!! :cheers:
Old Apr 14, 2003 | 10:10 AM
The Hobbit's Avatar
The Hobbit
Default Re: stupid question (AGENT 86)
vader86's Avatar
vader86
Check it at idle level in park and in D. Engine needs to be hot or rather warm.
To stupid question
