On the info center that says "check engine" "low colant" and many other things on my 86 I can see when the light hits it just right other legends like "choke" and "OD" in the upper left corner in something that ends with "ajar" it's not rear window that one lights up....
I didn't know this car had a choke, but should this other "ajar" and the "OD" light up if so they don't work on mine are these bulbs or is this thing a unit?
maybe someone could list what all is suppose to light on mine....
Thanks, :crazy: :thumbs:
Hum...so it's "door ajar" didnt know if it was door or hood...justr could see the "ajar" part,
Do you happen to know if these are bulbs in there a person can change or is that thing some unit that a person can't service....
Thanks....
There should be a bulb in there. Part #194 I believe, someone will correct me if I'm wrong. Take off the center bezel, and you'll see how it's mounted. Be careful with the wires when disconnecting them. While you are in there, I would replace all the bulbs. Took me about 20 mins to do all my DIC bulbs.
