Intake Manifold Leaking
Old Apr 16, 2003 | 08:56 PM
WhiskeyPapa's Avatar
WhiskeyPapa
Default Intake Manifold Leaking
This is an "amendment" to a thread I posted about my heads leaking.
I finally got the intake manifold off, and it's definately leaking oil...the heads aren't.
What worries me is this:
This crud was on the torx bolts holding the manifold down....
Anybody ever seen this???
Should I be worried, or will this go away when I re-seal it?
[Modified by WhiskeyPapa, 8:58 PM 4/16/2003]
Old Apr 16, 2003 | 09:00 PM
WhiskeyPapa
Default Re: Intake Manifold Leaking (WhiskeyPapa)
Ooops, I fixed the picture now.....
Old Apr 16, 2003 | 09:11 PM
cprgmr's Avatar
cprgmr
I would replace the bolt and make sure to put a little RTV on it when you reinstall the new one. :)
Old Apr 16, 2003 | 09:13 PM
scorp508's Avatar
scorp508
Default Re: Intake Manifold Leaking (cprgmr)
Those were the ones holding the manifold to the heads right? Hit em' with a wire wheel, put some teflon paste on the threads and reinstall. Check em' out 500 miles later.
Old Apr 16, 2003 | 09:15 PM
cprgmr's Avatar
cprgmr
Default Re: Intake Manifold Leaking (scorp508)
If you're cheap. Whenever you have rust, the original material is degraded. I wouldn't hesitate to replace one or two manifold bolts. :cheers:
Old Apr 16, 2003 | 09:17 PM
scorp508's Avatar
scorp508
If you're cheap.
Those bolts are coated. I'm willing to bet that isn't rust from them. It just looks like the sealer on the bolt has turned color.
Old Apr 16, 2003 | 09:18 PM
cprgmr's Avatar
cprgmr
That may be, but it looks like rust to me.
Old Apr 16, 2003 | 09:36 PM
WhiskeyPapa
Nope, it's just some goopy stuff, not rust....I was just wondering what it was if anybody knew. Some of them had a little bit of white stuff....maybe dried and heated coolant?????
Old Apr 16, 2003 | 09:38 PM
cprgmr's Avatar
cprgmr
You really could've fooled me man - that stuff on the right bolt really looks like rust!
Old Apr 16, 2003 | 09:43 PM
WhiskeyPapa
You'd think that from the pic, but it wiped right off (just w/ my fingers). If it's rust, it's awfully soggy rust. ;)
Old Apr 16, 2003 | 09:49 PM
WhiskeyPapa
By the way, I've got a photo of the top side on my web page w/out the manifold on it....the bolts were from the middle of the closer side (where it's a little bit dirty) :mad
[Modified by WhiskeyPapa, 9:50 PM 4/16/2003]
Old Apr 16, 2003 | 10:20 PM
Vic'89's Avatar
Vic'89
Hit the bolts with a wire wheel on a bench grinder. Takes all the junk off the bolts. Makes the installation easier also.
Vic
Old Apr 17, 2003 | 12:14 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Go to Sears and a thread chaser tap & die to clean up those bolts and the bolt holes.
Then coat the bolt threads with Permatex #2 before installing.
Old Apr 17, 2003 | 04:52 PM
86Pacecar's Avatar
86Pacecar
Just did my 86 and my bolts looked identical to yours. Cleaned right up with the wire wheel, used Perematex #2 before install. Be sure to clean up the bolt holes too so you will get proper torque when reinstalling. It's a fun job, isn't it.
To Intake Manifold Leaking
