RTV second try...
Old Apr 18, 2003 | 10:36 AM
devilfish's Avatar
devilfish
Default RTV second try...
..first try
http://forums.corvetteforum.com/zerothread?id=540237
We took of the intake base and cleand the gasget from the RTV.
This time we only put A thin layer on each side of the gasket. But when we tighten the bolts a bit of RTV squeezed out annyway??? :cry
Not half as much as before, but annyway...
IS that ok??
Old Apr 18, 2003 | 10:39 AM
MarkLT1's Avatar
MarkLT1
St. Jude Donor '04
Default Re: RTV second try... (devilfish)
yes.. thats fine. Just wipe away the excess that squeezes out.
Old Apr 18, 2003 | 12:42 PM
devilfish's Avatar
devilfish
Default Re: RTV second try... (MarkLT1)
im more worried about the RTV that squeezes out on the "other side" in to the water holes in the heads..
Or if som of the black RTV that I used on the short ends squeezes out into the engine??
[Modified by devilfish, 6:43 PM 4/18/2003]
Old Apr 18, 2003 | 12:55 PM
MrJay's Avatar
MrJay
It is ok if some off the RTV squeezed out, MarkLT1 is right just wipe it clean before it dryes because it is harder to clean when it dryes.
You dont have to worrie about it getting into the water because it is going to be dry before you put in the water.
Jay
Old Apr 18, 2003 | 01:00 PM
devilfish's Avatar
devilfish
Default Re: RTV second try... (MrJay)
so there is no danger in the rtv brake loose due to vibration?
Old Apr 18, 2003 | 01:05 PM
MrJay's Avatar
MrJay
RTV is really tuff and it looks like you did not put that much yes you can see something come out but not that much.
I would say if no RTV squeezed out then I think you put to little and it may leak later, but if you dont like it then you dont have to use RTV.
Jay
To RTV second try...
