Turn Signal Flasher Problem
Old Apr 18, 2003 | 08:42 PM
David Joseph's Avatar
David Joseph
Default Turn Signal Flasher Problem
The turn signal on my 93 LT1 is working erratically. It will flash for a while, then slow down. I think it is probably the flasher. Where is it located and is it hard to get at and replace?
Old Apr 18, 2003 | 11:32 PM
vetteguy216's Avatar
vetteguy216
Default Re: Turn Signal Flasher Problem (David Joseph)
My friend has a 95 sunfire that does the same thing he replaced the flasher but it didnt help. I cant think of what is causing it though?
Old Apr 19, 2003 | 12:47 AM
Steel Blue 91's Avatar
Steel Blue 91
If the emergency flashers work as they should, the problem should be the TS flasher. Left side of the steering column under the trim panel.
http://forums.corvetteforum.com/zerothread?id=537332
Old Apr 19, 2003 | 10:28 PM
David Joseph
Default Re: Turn Signal Flasher Problem (Steel Blue 91)
Hey, thanks, I located the bad flasher, replaced it and it is working fine! :auto: [IMG][/IMG]
To Turn Signal Flasher Problem
