comp cams just developed a new egg shaped (ls1 style) spring that fits in the stock spring pockets and if i remember correctly everything was near spec for the 74219 cam...which I reccomend. Are you ever going to change intakes?
I'll go with superram but I can't afford it all at once.
I wonder why they would do that? They already sell springs that fit the LT1's with no mods. :skep:
Quote:-
"I wonder why they would do that? They already sell springs that fit the LT1's with no mods."
If you look at Slidings profile it shows he owns a 90 L98. These use 1.24" valvesprings, that are smaller in diameter than the LT1's 1.30" valvesprings.
My heads guy says any performance cam will need stiffer springs, which
still won't last that long (30k mi, or 50k mi if you don't get on it that much)
anyway. With your new cam, you will have to change springs periodically.
I don't understand why a stiffer/new spring would only last 30k miles if you do a performance cam upgrade? Unless you do a very radical engine setup they should last at least as far as the stock ones no? :confused:
