Retro roller
Old Apr 19, 2003 | 06:27 PM
Ray383's Avatar
Ray383
Default Retro roller
Can my 85 hydraulic cam block be converted to a hydraulic roller cam? If so what parts do I need? Any machine work needed? What would be the cost? I would build an 87-up block, but I already have a 383 and don't want to build another. Thanks in advance for any help or thoughts.
Old Apr 19, 2003 | 06:31 PM
LD85's Avatar
LD85
Default Re: Retro roller (Ray383)
Cam button and retro roller lifters.
Old Apr 19, 2003 | 06:40 PM
PatsLs1vette's Avatar
PatsLs1vette
Default Re: Retro roller (ld85)
im using a roller cam in my 73 block with comp cams retro roller lifters, crane needle bearing cam button and works fine.
Old Apr 20, 2003 | 03:42 AM
eguyett1985's Avatar
eguyett1985
No big deal just use the Crane, Comp, or whoever retro-fit hyd. roller tappets, and cam thrust button. Be sure to use the correct timing set for the cam nose you have too
Old Apr 20, 2003 | 01:01 PM
Ray383's Avatar
Ray383
Default Re: Retro roller (eguyett1985)
Thanks for the help. Can I use any hydraulic roller cam, or do I need a "special" cam for my hydr. block?
To Retro roller
