Torx size for throttle blade adjustment..???
Old Apr 20, 2003 | 02:26 PM
DR76's Avatar
DR76
Default Torx size for throttle blade adjustment..???
1) What torx size is the trottle blade adjustment screw on a '95 Lt1?
2) HOW do you get to it w/o removing the throttle body?
I just put a 90' bend in a T-15 driver, in an attempt to adjust the blades a bit (have a slight split BLM problem, and IAC seems low...less than 10 at warm idle), but either T-15 is not correct, or I'm still not getting to the screw straight-on??? I wanted to adjust w/ engine running and look at data as I'm doing it, but intake and throtle cable bracket seem to be getting in my way :banghead:
Thanks!
Dr.
[Modified by DR'76, 1:28 PM 4/20/2003]
Old Apr 20, 2003 | 09:03 PM
STL94LT1's Avatar
STL94LT1
Default Re: Torx size for throttle blade adjustment..??? (DR'76)
My 94 TB adjustment screw is a T-20 torx.
I put just the torx bit in place, then turned it with a small ignition wrench.
It is a tight fit, hope this helps.
Old Apr 21, 2003 | 10:42 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Try torx wrenches shapped like an allen key. Each one is the diameter of the torx head so you can get deep into the bore. On my 86 the screw is pretty deep in the bore so a torx bit in a screwdriver handle may get too fat too fast and not fully reach the screw. :cheers:
To Torx size for throttle blade adjustment..???
