After seeing those numbers you'll have to change your name to "Mr Good Luck"; very nice results.
You might check the plugs and wires; also see if the TB & plates are carboned up. If so use some TB cleaner on them.
just had the plugs changed (2 of the wires were on reverse - thanks to the Dealer :mad: ) and wires were changed along with the ignition cable which was burned.
I'll check the TB this weeked hopefully. what's best cleaner to use?
[Modified by mikeg826, 3:16 PM 4/21/2003]
Got to love those dealers :banghead:
You can use TB cleaner or if you take it off use carb clean :cheers:
