SES light on
Old Apr 23, 2003 | 02:40 AM
JayH's Avatar
JayH
Default SES light on
While driving to work yesterday on the highway, I noticed the SES light on. It stayed on for a minute or so and then went off.
When I got in the car after work, it didn't start right up as usual - I had to leave the engine cranking for a few seconds before she weakly started up.
On the way home, again on the highway, she experienced a sudden surge for about a half a second and the SES light came on again and stayed on for a minute or so. No other problems last night except for another hard start after the grocery store.
I hooked up Datamaster to her tonight after driving my Jeep to work today, and there were no DTC's set. I drove for a half hour or so and didn't get the SES light at all, but I did notice the ASR lights and the AECC Off light blinking at me (se other threads.)
I'm going to run Datamaster on the way into work again tomorrow but until then, any ideas?
Jay
Old Apr 23, 2003 | 06:33 PM
JayH's Avatar
JayH
Default Re: SES light on (JayH)
ttt
Old Apr 24, 2003 | 01:40 PM
JayH's Avatar
JayH
Well, I found the cause of this. The ECT sensor that feeds the computer (and digi-dash,) is intermittenlty sending false signals of negative temperatures.
Since I just installed a 160 stat a few days before this started, I'm going to reset the ECM and if that doesn't do it, replace the sensor itself. Which one is that anyway? The one in the pump housing?
Jay
Old Apr 24, 2003 | 02:00 PM
SunCr's Avatar
SunCr
What year is your Vette? Sounds like an intermittent in the fuel pump circuit.
Old Apr 24, 2003 | 02:02 PM
JayH's Avatar
JayH
Default Re: SES light on (SunCr)
It's a '95, why does this sound like an intermittent in the fuel pump circuit to you? Do they share a common ground or something?
Jay
Old Apr 24, 2003 | 09:42 PM
SunCr's Avatar
SunCr
Fuel pump loses power - no gas - engine stalls - SES light comes on. Car is hard to start until the fuel rail is re-primed. Plugged fuel filter could cause the same symptoms. I'd check fuel pressure.
Old Apr 24, 2003 | 09:49 PM
JayH's Avatar
JayH
How does that relate to/explain the ECT sensor readings :confused:
Jay
Old Apr 24, 2003 | 10:14 PM
SunCr's Avatar
SunCr
It doesn't - that's a different problem. I was responding to your issue with a a check engine light, no codes, apparent stall & difficult to start - to me, it sounded like you ran out of gas; not literally of course.
Old Apr 24, 2003 | 10:19 PM
JayH's Avatar
JayH
I think that's the only problem as the fuel filter and fuel pump are relatively new. The ECM is trying to adjust the AFR based on the false ECT reading and that's what's causing the hesitation and the jump to open loop when it gets the false reading for too long. Since I first posted this, I saw the behavior in action and caught the code (that didn't get stored for some reason) when Datamaster logged it.
Jay
Old Apr 24, 2003 | 10:40 PM
SunCr's Avatar
SunCr
So post the code - should be a 14 or 15 if it's in the coolant temp circuit & the code would stay in history for 50 ignition cycles. Someone should be able to help.
To SES light on
