Are these TEMPS normal for an LT1?
Old Apr 23, 2003 | 09:34 AM
sundbergjc's Avatar
sundbergjc
Default Are these TEMPS normal for an LT1?
I'm a relatively new owner of a 95 LT1, 6M. I've been watching the engine temp in the digital mode which may not be really accurate, but at least it's relative. I drive about 12 miles to work and in light traffic, the temp hovers around 200. In heavy stop and go traffic, I've seen it up around 230 and I don't hear any fans coming on. Once I break free of the traffic, it comes back down pretty quickly. This is all without the AC on. When I punched on the AC with the temp at 230, it came down quickly to about 220. This is all with the outside temp no more than about 75-80. Does all this sound pretty normal or indicate some problem?
Thanks, John :confused:
Old Apr 23, 2003 | 09:47 AM
don hall's Avatar
don hall
Default Re: Are these TEMPS normal for an LT1? (sundbergjc)
.. Does all this sound pretty normal?..
Quite normal....
Richard G's Avatar
Richard G
I have had my Corvette now for about a year. Those temps seem normal according to my 94 LT1. When your temps dropped rapidly that indicated to me that both your fans kicked on when AC was started. These cars naturally run hot. The guys on this forum will tell you to be sure and keep radiator clean!
Old Apr 23, 2003 | 10:16 AM
vader86's Avatar
vader86
Its normal to see those temps. The LT1 likes to run a little hotter.
But Id make sure it doesnt see temps over 230 regularly, thats pretty hot, and engines dont make the optimum power up there.
I would still remove the radiator shroud and clean in between the condenser and radiator, that will lower those temps by a good 10F. Id also flush the system and refill. You can switch to a 160 thermo if you wish, but the LT1 already has a 180.
But if it worries you then Id get a hypertech PP and change the fan settings or wire in a fan switch to make the main fan come on earlier.
Old Apr 23, 2003 | 10:24 AM
sundbergjc's Avatar
sundbergjc
Default Re: Are these TEMPS normal for an LT1? (vader86)
Good thoughts. Thanks!
Old Apr 23, 2003 | 10:29 AM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
Everything looks normal except for one comment you made...the fans should come on at 228 degrees without the a/c on which is the factory setting...you say you can't hear them come on...double check that to make sure...when you turn on the a/c they come on immediately no matter what temp your coolant is at.. good luck
Old Apr 23, 2003 | 10:53 AM
_freakmonkeydogboy_'s Avatar
_freakmonkeydogboy_
Default Re: Are these TEMPS normal for an LT1? (Oldman)
Quite normal....
:withstupid:
Old Apr 23, 2003 | 10:58 AM
GlockLT4's Avatar
GlockLT4
Default Re: Are these TEMPS normal for an LT1? (_freakmonkeydogboy_)
I hate anything above 200 :nonod:
Old Apr 24, 2003 | 12:10 AM
LTs LT1's Avatar
LTs LT1
I have a 96 LT1 and it ran the same. I put in a hypertech 160 thermo, and it now stays around 175 while moving, and goes up to around 190-200 stopped in traffic.
Old Apr 24, 2003 | 12:15 AM
silver & red CE's Avatar
silver & red CE
Mine was running that hot, then I had my PCM reprogrammed so it wouldn't. I keep thinking those kind of temp variations can't be good for the head gasket.
Eric
Old Apr 24, 2003 | 12:33 AM
R23HTC's Avatar
R23HTC
Default Re: Are these TEMPS normal for an LT1? (silver & red CE)
Normal for a normal LT1. You might check the radiator to make sure it doesn't look like this one. :mad
Cleaning it will drop it a few degrees. :D
[Modified by R94 LT 1, 11:39 PM 4/23/2003]
Old Apr 24, 2003 | 09:54 AM
Tom Meehan's Avatar
Tom Meehan
Try Water Wetter. I had the same concern and it dropped the temperature about 15 degrees all around. It's the cheapest first step. Here in Houston, we run into those temps all the time.
Old Apr 24, 2003 | 02:59 PM
richy rich's Avatar
richy rich
Default Re: Are these TEMPS normal for an LT1? (Tom Meehan)
For what its worth my 94 ran at that same temp.One day i decided to change the cam & when I pulled the rad out it was clean[40000 miles]but very heavy!At this point I had the rad flushed[for 20 bucks cash we should all be flushing]The guy at the rad shop says it was plugged-when I got it back it was much lighter.Well it still ran up to 230. in traffic.I then used a hypertech & 160 stat & now it stays around 170-180.If it worries you flush your WHOLE system for piece of mind!
Old Apr 24, 2003 | 03:43 PM
Irishpilot03's Avatar
Irishpilot03
Default Re: Are these TEMPS normal for an LT1? (richy rich)
I have the 160 degree thermostat and I see 175-177 on the highway, even at 85mph+, but around town I see 185. If you don't like the high temps, I would suggest replacing your thermostat.
To Are these TEMPS normal for an LT1?
