L98 Head Swap
Old Apr 23, 2003 | 12:42 PM
Cruz 86's Avatar
Cruz 86
Default L98 Head Swap
My 86 has the factory cast iron heads. If I switch to 113 aluminum heads will my intake bolt right up to them.
Old Apr 23, 2003 | 02:40 PM
dgoodhue's Avatar
dgoodhue
Default Re: L98 Head Swap (Cruz 86)
In 87 GM change the middle intake bolt angles. You can elongate your holes to fit this angle or you can use a aftermarket TPI base (accell edblebrock which are both double drilled) or a stock 87 up base.
