Question about brakes...
Old Apr 24, 2003 | 03:50 AM
CMYC4GO's Avatar
CMYC4GO
Default Question about brakes...
Last August, my brakes started chirping while the car was in motion, Apply the brakes, and the chirp went away. I had the brakes looked at, and there was no problem found. The chirp continued to get worse, so I had the pads replaced w/OEM pads, and also went to the expense of installing new rotors all the way around. The chirp stopped for about a week, and then returned. Now it is chirping loud enough that people are starting to turn their heads, and look at me. I have had the car checked again, and have been assured that there is no problem. The car stops fine, but there IS a problem somewhere.....otherwise, there would not be this very annoying, and embarassing chirp. Any ideas? :banghead:
[Modified by Klimper, 2:51 AM 4/24/2003]
Old Apr 24, 2003 | 09:14 AM
Aaron71771's Avatar
Aaron71771
Default Re: Question about brakes... (Klimper)
Is it a chirp or a rattle? Does it sound like it's comming from front or rear? Might want to check that they put anti-squeek on the back of the pads.
