window switch
Old Apr 25, 2003 | 01:20 PM
Formula 94 LT1's Avatar
Formula 94 LT1
Default window switch
Do you have to have an ignition box for one of these? All I need now is a bottle heater, window switch, WOT switch, nitrous filter, and maybe a pressure gauge mine might be broken....
Old Apr 25, 2003 | 02:16 PM
VetteNoob's Avatar
VetteNoob
Default Re: window switch (Formula 94 LT1)
No, the window switch can be connected to the tach wire or the tach to PCM signal wire to work.
Old Apr 25, 2003 | 03:31 PM
fsr402's Avatar
fsr402
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Default Re: window switch (VetteNoob)
Anyone know what wire that would be? Any pictures would help..
Old Apr 25, 2003 | 03:51 PM
VetteNoob's Avatar
VetteNoob
Default Re: window switch (fsr402)
According to Accel.
LT1
Look for a white or white with a black stripe either off the 32-pin connector underneath the air cleaner, or off the ICM (ignition coil module (coil pack)) and tap into for the engine RPM signal. (4 PPR)
To window switch
