Front Air Dam is scraping
Old Apr 25, 2003 | 09:33 PM
Jerry D's Avatar
Jerry D
Default Front Air Dam is scraping
My 1986 sits very low in the front and scrapes all the time whenever I go over any small incline. Is there a way to lift the front end a couple of inches without causing any problems? Thanks Jerry
Old Apr 25, 2003 | 10:00 PM
Bear86's Avatar
Bear86
Default Re: Front Air Dam is scraping (Jerry D)
My 86 does the same thing. I figured it was the nature of the beast.
Be C :cool: :cool: L & :seeya :seeya :seeya
Old Apr 25, 2003 | 10:03 PM
bill mcdonald's Avatar
bill mcdonald
Sounds like it is time for you to install some hydros. :jester
Old Apr 25, 2003 | 11:54 PM
Jerry D's Avatar
Jerry D
Default Re: Front Air Dam is scraping (bill mcdonald)
What the heck are Hydros? :rolleyes:
Old Apr 26, 2003 | 04:57 AM
jtfrog's Avatar
jtfrog
hydralics :lol:
Old Apr 26, 2003 | 09:20 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Trim the air dam an inch or so!! :cheers:
Old Apr 26, 2003 | 09:39 AM
SonnyinVA's Avatar
SonnyinVA
Default Re: Front Air Dam is scraping (AGENT 86)
the air dam is trimming itself... lol jsut leave it. it'll be ok. thsoe are relatively cheap to replace anyway even if you have to do it every few years.
you would not want to raise the front end, that is bass ackwards. everybody else is trying to lower there cars...
all you have to do is approach inclines and declines at an angle, and then you won't scrub or at least will scrub much less. just takes some getting used to and awareness of the road. :cheers:
Old Apr 26, 2003 | 02:05 PM
Jerry D's Avatar
Jerry D
Default Re: Front Air Dam is scraping (SonnyinVA)
Thanks, sounds like good advice especially the trimming. I'm a rookie so it'll take time getting used to the scraping. :D :lol:
Old Apr 26, 2003 | 02:08 PM
GlockLT4's Avatar
GlockLT4
yeah, takes some time getting used to like it did from me going from an SUV to a vette. You can order the front spoiler kit for 92-96 for $40 from Mid america .. not sure on the '86 though. I would guess it's the same part, but who knows.
LT4Sam's Avatar
LT4Sam
Damn, mine scrapes getting out of my driveway. It's funny, it rarely scrapes on the way in but always on the way out, and I turn the wheel the same for both. Just get used to it and try to minimize it.
Sam
Old Apr 26, 2003 | 02:11 PM
Jerry D's Avatar
Jerry D
Default Re: Front Air Dam is scraping (LT4Sam)
Hi Sam
Yeah mine is the same no scraping going in up my driveway but backing out is nasty. I tried different angles so I guess I'll have to get used to it and just take it slow. Thanks Jerry
Old Apr 26, 2003 | 02:15 PM
Jerry D's Avatar
Jerry D
Default Re: Front Air Dam is scraping (GlockLT4)
Thanks for the info! I'll just scrape it until there ain't no more to scrape. :)
Old Apr 26, 2003 | 02:19 PM
GlockLT4's Avatar
GlockLT4
haha ... just make sure you don't wear the entire thing off or your car won't cool enough.
Old Apr 26, 2003 | 02:24 PM
vetracer's Avatar
vetracer
They must have done something to the front spring in '86 because they all appear to sit a little lower in front. I put a Z51 front spring off an '85 on mine and it sits level now and doesn't scrape nearly as bad as it used to. Rides and handles great, too. I had put the rear Z51 spring in too but removed it because it was waay too stiff. If you look at spring rates through the years GM kept softening up the rear spring (softest was in '96) so I wouldn't worry about mixing springs from different performance packages.
Also, GM made several air dams over the years too and if you replaced yours with a longer one (the Z51 air dam is the longest) that may have contributed to the problem as well.
[Modified by vetracer, 12:25 PM 4/26/2003]
Old Apr 26, 2003 | 02:30 PM
Jerry D's Avatar
Jerry D
Ok Thanks
Old Apr 26, 2003 | 02:31 PM
Jerry D's Avatar
Jerry D
Default Re: Front Air Dam is scraping (vetracer)
Where did you get the Z51 springs?
Old Apr 26, 2003 | 03:12 PM
StealDads67's Avatar
StealDads67
And it sounds worse then it really is too.... Get your angles down and you'll be fine
To Front Air Dam is scraping
Old Apr 26, 2003 | 05:21 PM
JWG's Avatar
JWG
St. Jude Donor '07
Get use to it, and don’t worry about it. Everybody here scrapes now and than....................... :D
Old Apr 27, 2003 | 12:38 AM
vetracer's Avatar
vetracer
If you call around some wrecking yards, they are out there, and pretty cheap, too.
Old Apr 27, 2003 | 03:44 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Maybe you should lower the rear more. When I dropped my rear 1.25" I think the front air dam went up like 1/4" or so.
