Something snapped
Old Apr 26, 2003 | 02:12 AM
djbraxton's Avatar
djbraxton
Default Something snapped
Well, took the vette to the track for the first time after the motor was rebuilt.
And on mine second pass, I broke something in the rear. I think it was a u-joint, hopefully, will examine later. I see people running their vettes on the strip all the time, what can I do to fortified the rear-end...I maybe rambling alittle, but I pretty pissed right now...
Thanks for you ideas :mad
Old Apr 26, 2003 | 02:48 AM
Steve85's Avatar
Steve85
Cruise-In V Veteran
Default Re: Something snapped (djbraxton)
Sooner or later everything breaks. If those are the original U-joints I'd say you got good life, sounds like the car is no stranger to the track. I'm sure someone will give you a lead on some HD parts for the rear.
In the meantime, just remember,
"Racing can make you rich...so long as you start out filthy stinking rich" :yesnod:
Old Apr 26, 2003 | 03:58 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
I hope for your sake, it was a u-joint also... and not a pinion
I guess that motor must be hot stuff then right?
[Modified by CentralCoaster, 12:59 AM 4/26/2003]
Old Apr 26, 2003 | 10:51 PM
djbraxton's Avatar
djbraxton
Default Re: Something snapped (CentralCoaster)
This must be my lucky day, snapped two ends of the outter u-joint but I'm going to have to find another half shaft. I guess when I drove off the track, it ate up the end of the shaft while it was moving around...
Later
To Something snapped
