91 Dash Cluster Fix
Old Apr 26, 2003 | 08:50 AM
cshuman's Avatar
cshuman
Default 91 Dash Cluster Fix
My cluster starting jumping around a while back an continually got worse. I took it out, checked it over, then stuck it back in without screwing it down. One of guys had said that they just had a loose connection. I drove the car around to see how it acted with out it being screwed down so I could push on the corner where the connection plug is to see if affected it. To my supprise it didn't jump around at all. So I put everything back together and it has stopped completely. I think that maybe over the years that the contact points on the connection had gotten dirty, and after taking the cluster in and out those few times swiped the contacts enough to allow it to get a good contact.
Maybe it anyone has this porblem they can give it a try.
PS. The easy way to get that damn thing out is to drop the under dash carpeted cover remove the metal shield under that to access the two bolts that hold up the stearing column, remove them, and drop the column down, remove the 4 screws that hold the cluster trim in, and then you can remove the 4 screws that hold the cluster itself. Its also a good time to clean up the clear cover on the front of the cluster.
Old Apr 26, 2003 | 02:03 PM
madquake's Avatar
madquake
Default Re: 91 Dash Cluster Fix (cshuman)
You have the digital dash correct ??
My 93 roadster does the same .... it seems to work perfectly at times and then it garbles up really bad and eventually it blanks out and then when I go over some tracks or bump ... It pops back On.... makes me really :mad
Thanks for the tip on taking it out I tried taken it out one time and gave up
half way into it.
Gonna get a can of air and some screwdrivers and get this done really soon
see if this help!!
Thanks again Mark A.
Old Apr 27, 2003 | 10:09 AM
cshuman's Avatar
cshuman
Default Re: 91 Dash Cluster Fix (madquake)
Yes I do. The speedo is the only digital item. The others are analog or dials.
Old Apr 27, 2003 | 12:05 PM
Rob 93ZR-1's Avatar
Rob 93ZR-1
From: Fear causes hesitaiton...and hesitation will cause your worst fears to come true. Houston TX
Cruise-In IV Veteran
Cruise-In VII Veteran
Good info. Hope your fix is permanent. :cheers:
To 91 Dash Cluster Fix
